The LMC6482 device has a common-mode range that includes both supply rails. This device's rail-to-rail performance, combined with excellent accuracy due to a high CMRR, distinguishes it among rail-to-rail input amplifiers. The device is an excellent choice for systems requiring a wide input signal range, such as data acquisition. The LMC6482 is also an excellent upgrade for circuits that use TLC272 and TLC277 limited common-mode range amplifiers.
The rail-to-rail output swing of the LMC6482 provides maximum dynamic signal range in low voltage and single supply systems. For loads as low as 600, the rail-to-rail output swing is maintained. The LMC6482 is an excellent choice for battery-powered systems due to its specified low-voltage characteristics and low power dissipation.
cannoonmaadden
