CR2032 batteries and CR2016 batteries that are round, flat, and resemble small silver buttons can appear to be the same at times. Can they be used universally because they all look the same?
Stop! Wait a second!
Although the CR2032 and CR2016 batteries are similar, there are DIFFERENCES in battery thickness and capacity. As a result, we can't just use the two batteries.
If you make an error by accident, you will have to place a new order to purchase it lol. So, to clarify the difference between a CR2032 battery and a CR2016 battery, and to avoid being confused by their similar appearance when purchasing the battery, read the following.
cannoonmaadden
It's simple. 2032 is 20mm diameter and 3.2mm thick. 2016 is 20 mm diameter and 1.6 mm thick.
