Product Overview
The BNO055 is a System in Package (SiP), integrating a triaxial 14-bit accelerometer, a triaxial
16-bit gyroscope with a range of ±2000 degrees per second, a triaxial geomagnetic sensor
and a 32-bit cortex M0+ microcontroller running Bosch Sensortec sensor fusion software, in
a single package.
The corresponding chip-sets are integrated into one single 28-pin LGA 3.8mm x 5.2mm x
1.1 mm housing. For optimum system integration the BNO055 is equipped with digital bidirectional I2C and UART interfaces. The I2C interface can be programmed to run with the
HID-I2C protocol turning the BNO055 into a plug-and-play sensor hub solution for devices
running the Windows 8.0 or 8.1 operating system.
This blog will introduce BNO055 systematically from its features, pinout to its specifications, applications, also including BNO055 datasheet and so much more.
BNO055 Features
- Includes all sensors, sensor hub and optimized software
- Low power consumption, supports various power modes for switching sensors on and off and algorithm modules to speed code development
- Advanced 9-axis sensor fusion algorithms
- Fast background calibration of all sensors and calibration monitor while in use
- Enhanced magnetic distortion detection and suppression
- Real-time motion tracking due to built-in group delay compensation
- Gyroscope drift cancellation
- Supports multiple operating mode, i.e. 6-axis based applications (inertial measurement Units)
- 3-axis accelerometer (14Bit)
- 3-axis gyroscope (16Bit)
- 3-axis geomagnetic sensor
- 32 bit ARM Microcontroller
- 5.2 x 3.8 mm² footprint
- Bosch Sensortec Sensor Data Fusion with fast magnetic calibration (optimally integrated & tuned)
BNO055 Components
If you want to know more about BNO055, you can read its datasheet.
