Product Overview
The AD8605 are single, dual, and quad rail-to-rail input and output, single-supply amplifiers. They feature very low offset voltage, low input voltage and current noise, and wide signal bandwidth. They use the Analog Devices, Inc. patented DigiTrim® trimming technique, which achieves superior precision without laser trimming.
This blog will introduce AD8605ARTZ systematically from its features, pinout to its specifications, applications, also including AD8605ARTZ datasheet and so much more.
AD8605ARTZ Features
- Low offset voltage: 65 μV maximum
- Low input bias currents: 1 pA maximum
- Low noise: 8 nV/√Hz
- Wide bandwidth: 10 MHz
- High open-loop gain: 1000 V/mV
- Unity gain stable
- Single-supply operation: 2.7 V to 5.5 V
- Photodiode amplification
- Battery-powered instrumentation
- Multipole filters
- Sensors
- Barcode scanners
- Audio
AD8605ARTZ Pinout
The following figure is the diagram of AD8605ARTZ pinout.
AD8605ARTZ Applications
- Multipole filters
- Sensors
- Barcode scanners
- Audio
If you want to know more about AD8605ARTZ, you can read its datasheet.
