NE5532 Vs. TL072: What Is The Difference?
ericksonbrecken1998ericksonbrecken1998 wrote 03/21/2022 at 03:59 • • 3 min read • Like
NE5532 Overview
The NE5532 is a high-performance, low-noise operational amplifier with twin channels. It outperforms most typical operational amplifiers, including 1458, in terms of noise performance, output drive capability, and small-signal and power bandwidths.
As a result, the device is particularly well-suited for use in high-quality and professional audio equipment, instrumentation and control circuits, and telephone channel amplifiers. For gains of one, the op amp is internally adjusted. If very low noise is critical, the 5532A variant is recommended because it has guaranteed noise voltage standards.
TL072 Overview
The TL072 is a high-speed J–FET input dual operational amplifier with well-matched high voltage J–FET and bipolar transistors in a monolithic integrated circuit. High slew rates, low input bias and offset currents, and a low offset voltage temperature coefficient characterize the devices.
NE5532 Pinout
TL072 Pinout
NE5532 Equivalents
Part NumberDescriptionManufacturer
TL082CDR2AMPLIFIER CIRCUITSOperational Amplifier, 2 Func, 20000uV Offset-Max, BIPolar, PDSO8, PLASTIC, SO-8Motorola Semiconductor Products
TL072ACNAMPLIFIER CIRCUITSJFET inputs, low input bias currentSTMicroelectronics
UPC4560CAMPLIFIER CIRCUITSOperational Amplifier, 2 Func, 6000uV Offset-Max, BIPolar, PDIP8, 0.300 INCH, PLASTIC, DIP-8NEC Electronics Group
UPC1458CAMPLIFIER CIRCUITSOperational Amplifier, 2 Func, 6000uV Offset-Max, BIPolar, PDIP8, 0.300 INCH, PLASTIC, DIP-8NEC Electronics Group
MC1558UGAMPLIFIER CIRCUITSOperational Amplifier, 2 Func, BIPolar, CDIP8, LEAD FREE, CERAMIC, DIP-8Motorola Semiconductor Products
TL082MJGAMPLIFIER CIRCUITSIC,OP-AMP,DUAL,BIPOLAR/JFET,DIP,8PIN,CERAMICFreescale Semiconductor
MC4558L-D08-TAMPLIFIER CIRCUITSOperational Amplifier, 2 Func, 6000uV Offset-Max, BIPolar, LEAD FREE, DIP-8Unisonic Technologies Co Ltd
MC33178PAMPLIFIER CIRCUITSIC,OP-AMP,DUAL,BIPOLAR,DIP,8PIN,PLASTICFreescale Semiconductor
MC4558UAMPLIFIER CIRCUITSOperational Amplifier, 2 Func, 5000uV Offset-Max, BIPolar, CDIP8, CERAMIC, DIP-8Motorola Semiconductor Products
TA75071PAMPLIFIER CIRCUITSIC OP-AMP, 10000 uV OFFSET-MAX, 3 MHz BAND WIDTH, PDIP8, 0.300 INCH, 2.54 MM PITCH, PLASTIC, DIP-8, Operational AmplifierToshiba America Electronic Components
The Differences Between NE5532 And TL072 In Features
NE5532 Features:
• Small-Signal Bandwidth: 10 MHz
• Output Drive Capability: 600 , 10 VRMS
• Input Noise Voltage: 5.0 nV Hz  (Typical)
• DC Voltage Gain: 50000
• AC Voltage Gain: 2200 at 10 kHz
• Power Bandwidth: 140 kHz
• Slew Rate: 9.0 V/s
• Large Supply Voltage Range: 3.0 to 20 V
• Compensated for Unity Gain
• Pb−Free Packages are Available
TL072 Features:
• High slew rate: 20 V/μs (TL07xH, typ)
• Low offset voltage: 1 mV (TL07xH, typ)
• Low offset voltage drift: 2 μV/°C
• Low power consumption: 940 μA/ch (TL07xH, typ)
• Wide common-mode and differential voltage ranges
– Common-mode input voltage range includes VCC+
• Low input bias and offset currents
• Low noise: Vn = 18 nV/√Hz (typ) at f = 1 kHz
• Output short-circuit protection
• Low total harmonic distortion: 0.003% (typ)
• Wide supply voltage: ±2.25 V to ±20 V, 4.5 V to 40 V
NE5532 needs lower noise voltage than TL072, the high slew rate of NE5532 is also lower than TL072.
The Differences Between NE5532 And TL072 In Applications
NE5532 Applications:
• AV Receivers
• Embedded PCs
• Netbooks
• Video Broadcasting and Infrastructure: Scalable Platforms
• DVD Recorders and Players
• Multichannel Video Transcoders
• Pro Audio Mixers
TL072 Applications:
• Solar energy: string and central inverter
• Motor drives: AC and servo drive control and power stage modules
• Single phase online UPS
• Three phase UPS
• Pro audio mixers
• Battery test equipment
The NE5532 outperforms the TLO72 in almost every aspect of audio application, with the only significant exception being the 5532s' unusually large input current requirement. The TLO72 has extremely little load driving capability, is prone to latching up if the inputs are overloaded, and has a slew of other "features" that make it unsuitable for audio.
TL072 is another well-known operational amplifier that is frequently compared to the NE5532 in order to determine which is quieter. The bipolar transistor inputs of the NE5532, on the other hand, draw input current and are not the same as the JFET inputs of the TL072, which have no input current. As a result, the NE5532 is three times quieter when the source impedance is exceptionally low (defined at 20 ohms). They have equal noise levels when the source impedance is roughly 18.5k ohms, because the input current noise adds to the NE5532's input voltage noise. When the source impedance is greater than roughly 18.5k, the TL072 is quieter. A NE5532 is commonly seen as a phonograph cartridge, tape head, or microphone preamp with a huge input coupling capacitor that takes an eternity to charge. The low impedance of the large input cap reduces input current noise.
Like
lostintheethes wrote 11/09/2023 at 03:58 • point
For more information on the NE5532 and TL072, take a look: https://www.perceptive-ic.com/products?action=model&keyword=NE5532   https://www.perceptive-ic.com/products?action=model&keyword=TL072
