SOT23 vs SOT323 Overview
SOT23 and SOT323 are both plastic and surface-mounted packages. SOT23 owns 3 terminals, 1.9mm pitch, 2.9mm x 1.33mm x 1mm body, while SOT323 boasts 3 leads, 1.3mm pitch, 2mm x 1.25mm x 0.95mm body.
SOT23 vs SOT323 Pinout
SOT23 and SOT323 Differences In Feature
1.Two-line bidirectional ESD protectionl For CAN-Bus applications and interface ESD protection
2. Compact SOT-323 and SOT-23 packages
3. Low package height:
-SOT-323: 1.1mm
-SOT-23: 1.2mm
4. AEC-Q101 qualified versions available
5. Working range:
-VCAN16A2: ±16V
-VCAN33A2: ± 33V
6. Low leakage current: <0.05μA
7. Low load capacitance typical CD:
-VCAN16A2: ±16V, <18.5pF at 0V
-VCAN33A2: ±33V, <9.7pF at 0V
8. ESD protection acc. IEC 61000-4-2:
-±30kV contact discharge
-±30kV air discharge
9. Soldering can be checked by standard vision inspection (AOI = automated optical inspection)
10. e3 – pins plated with tin (Sn)
The Parameters Differences In SOT23 And SOT323
| Dimensions (mm) | ||
| SOT23 | SOT323 | |
| A | 2.9 | 2.9 |
| B | 1.3 | 1.3 |
| C | ||
| D | ||
| G | 1.9 | 1.3 |
| H | ||
| J | ||
| K | ||
| L | 0.95 | 0.65 |
| S | ||
| V |
From the image and the diagram, we can see that there are two different dimensions in SOT23 and SOT323: The length of G is 1.9mm and 1.3mm and L is 0.95mm and 0.65mm respectively. When using the packages, we should check whether these two dimensions fit the component or not.
The Package Outlines of SOT323 and SOT23
SOT23 Package Outline
The Parameters Of SOT23 Package
SOT323 Package Outline
The Soldering Differences in SOT23 and SOT323
Reflow Soldering
Wave Soldering
Conclusion
From above, we can know that there are a few differences between SOT23 and SOT323. For instance, the pitch of SOT323 is 0.6mm small than that of SOT23, and SOT323’s dimensions of body are smaller than SOT23’s, etc. There are various similarity between them, but we should check the detailed dimensions when using them.
ericksonbrecken1998
