2SC945 Description
The 2SC945 is a high-frequency OSC NPN audio frequency amplifier transistor. It is an old Japanese bipolar audio NPN transistor, which has been widely used in high-frequency circuits for pre-amplification in amplifier applications.
2SC945 Features
1. Power dissipation of 0.4Watts.
2. Collector current of 0.15A.
3. Collector-base Voltage: 60 volts
4. Operating and storage junction temperature range: -55°C to +150°C • Epoxy has a flammability grade of UL 94 V-0
5. Level 1 Moisture Sensitivity
2SC945 Pinout
2SC945 CAD Model
Symbol
Footprint
3D Model
Specifications
Package:TO-226-3, TO-92-3 (TO-226AA) (Formed Leads)
Operating Temperature: -55°C~150°C TJ
Pin Count: 3
Packaging: Tape & Box (TB)
Transistor Type: NPN
Transition Frequency: 150MHz
Number of Terminations: 3
2SC945 Equivalents
2SC2856TRANSISTORS, MPSA56/D26Z{OPTION18}TRANSISTORS, KSC2310-OTRANSISTORS, BC368-16TRANSISTORS, BSS38TRANSISTORS, ZTX455QTRANSISTORS, JC557ATRANSISTORS, BC546BRL1TRANSISTORS, ZTX450TRANSISTORS, BC546B-AMMOTRANSISTORS
Applications
1. Switches with low current
2. Pre-amplifiers
3. Low-power motor H-bridge circuits
4. Circuits for audio frequency amplifiers
5. Oscillator circuits
Where To Use 2SC945
Because it has a low base voltage of 5V, it can be easily controlled by an MCU/MPU if used as a switch. It can switch loads of up to 50 volts. With its complementary A733 PNP transistor, it can also be used as an oscillator.
Package
Manufacturer
Founded in 1991, Micro Commercial Components Corp. (MCC) is a manufacturer of high-quality discrete semiconductors to the consumer markets. It provides diodes, rectifiers, transistors, MOSFETs, voltage regulators and protection devices.
Datasheet
https://pdf.easybom.com/r/datasheets/microcommercialco-2sc945grap-datasheets-7531.pdf
Check out more details on: https://www.easybom.com/blog/a/the-introduction-of-2sc945
ericksonbrecken1998
