2N4401: NPN Transistor, Pinout, Datasheet
ericksonbrecken1998ericksonbrecken1998 wrote 04/09/2022 at 02:27 • • 4 min read • Like
2N4401 Description
The 2n4401 is a bipolar junction transistor with an NPN junction that is used for general purpose amplification and switching. Conduction is carried out by both charge carriers, i.e. electrons and holes, in a bipolar junction transistor. However, electrons will be the majority charge carriers.
2N4401 Features
The collector current (IC) is 500mA on a continuous basis.
The voltage between the collector and the emitter (VCE) is 40 volts.
The collector-base voltage (VCB) is set to 60 volts.
6V is the Emitter Base Breakdown Voltage (VBE).
100MHz is the transition frequency.
To-92 package is available.
General-purpose NPN Transistor
High DC Current Gain (hFE), typically 80 when IC=10mA
2N4401 Pinout
无
无
2N4401 CAD Model
 Symbol
无
Footprint
无
3D Model
无
2N4401 Equivalents
Part NumberDescriptionManufacturer
2N4401RLRETRANSISTORSSmall Signal Bipolar Transistor, 0.6A I(C), 40V V(BR)CEO, 1-Element, NPN, Silicon, TO-92Motorola Semiconductor Products
2N4401TFRTRANSISTORS600mA, 40V, NPN, Si, SMALL SIGNAL TRANSISTOR, TO-92, LEAD-FREE, TO-92, 3 PINRochester Electronics LLC
2N4401D74ZTRANSISTORSSmall Signal Bipolar Transistor, 0.6A I(C), 40V V(BR)CEO, 1-Element, NPN, Silicon, TO-92Fairchild Semiconductor Corporation
2N4401BUTRANSISTORS600mA, 40V, NPN, Si, SMALL SIGNAL TRANSISTOR, TO-92, LEAD FREE, TO-92, 3 PINRochester Electronics LLC
2N4401TATRANSISTORSNPN Bipolar Junction Transistor, TO-92, 2000-FNFLDonsemi
2N4401_J05ZTRANSISTORSSmall Signal Bipolar Transistor, 0.6A I(C), 40V V(BR)CEO, 1-Element, NPN, Silicon, TO-92, LEAD FREE, TO-92, 3 PINFairchild Semiconductor Corporation
2N4401RLTRANSISTORS600mA, 40V, NPN, Si, SMALL SIGNAL TRANSISTOR, TO-92, CASE 29-11, TO-226AA, 3 PINonsemi
2N4401RLRAGTRANSISTORS600mA, 40V, NPN, Si, SMALL SIGNAL TRANSISTOR, TO-92, LEAD FREE, CASE 29-11, TO-226AA, 3 PINRochester Electronics LLC
2N4401RLRPTRANSISTORS600mA, 40V, NPN, Si, SMALL SIGNAL TRANSISTOR, TO-92, CASE 29-11, TO-226AA, 3 PINRochester Electronics LLC
2N4401-APTRANSISTORSSmall Signal Bipolar Transistor, 40V V(BR)CEO, 1-Element, NPN, Silicon, TO-92, ROHS COMPLIANT, PLASTIC PACKAGE-3Micro Commercial Components
Specifications
Package / Case: TO-226-3, TO-92-3 (TO-226AA) (Formed Leads)
Packaging: Bulk
Operating Temperature: -55°C~150°C TJ
Voltage - Collector Emitter Breakdown (Max): 40V
Transistor Type: NPN
Mounting Type: Through Hole
2N4401 Applications
1. It has the ability to switch high-current loads (up to 500mA).
2. It can be used in a wide range of switching applications.
3. Controlling the speed of the motor
4. Inverter and other rectifier circuits
5. It can be employed in Darlington Pair.
2N4401 Package
无
2N4401 Manufacturer
On Semiconductor (Nasdaq: ON) is a manufacturer engaging itself in reducing energy use. It features a comprehensive portfolio of power, signal management, and logic, custom solutions that are energy efficient. It acts as a world-class supply chain with high reliability and a network of manufacturing facilities, sales, offices, and design centers in key markets through North America, Europe, and the Asia Pacific regions.
2N4401 vs 2N3904
In every way, the 2N3904 and 2N4401 look to be quite similar parts. The 2N4401 has a greater current rating, but otherwise, they appear to be similar in pricing and other aspects.
2N4401 vs 2N2222
The 2N4401 transistor is extremely similar to the widely used 2N2222 NPN transistor. The 2N4401 and the 2N2222, on the other hand, have two major variances. When compared to 2N2222, the 2N4401 has a collector current limit of 500mA and power dissipation of 652mW, making it appropriate for medium loads, but it can also drive loads bigger than BC547.
Frequently Asked Questions In 2N4401
What is 2N4401?
The 2n4401 is a bipolar junction transistor with an NPN junction that is used for general-purpose amplification and switching. Conduction is carried out by both charge carriers, i.e. electrons and holes, in a bipolar junction transistor. However, electrons will be the majority charge carriers.
What is the difference between 2N3904 and 2N4401?
Datasheet
https://pdf.easybom.com/r/datasheets/onsemiconductor-mmbt4401-datasheets-1046.pdf
Like
