Looking for a PCB Mill that can remove/copper / drill holes with .1 spacing
Ralphw wrote 05/15/2022 at 14:40 0 points
I'm trying to find a modest CNC machine that can drill a copper-plated PCB.
This would hopefully be an alternative to using chemicals to etching the copper traces from the PCB.
This will help me move from wire-wrap construction to PCBs.
Ideally, the solution would:
* take in a Gerber file (on the host machine running linux)
* send positioning commands to the motor
Boards would have about 15-20 chips onboard, so 500 holes for  ICs would be topical,  another 100 holes for discrete components, and 100 holes for the bus connector.
ask
