For a matter of symmetry and sake of schematic drawing I have rearranged the wiring, so the MSX pin 8, a push-pull output became an open collector with pull-up resistor, then the pins/rows assignment became
ROW / (Keys) | MSX Joystick Pin | Keyb. Contr. Pin |
0 / ( #, 9, 6, 3 ) | 8 | 6 |
1 / ( 0 , 8, 5, 2 ) | 6 | 9 |
2 / ( *, 7, 4, 1 ) | 7 | 5 |
Or in colors, lol!
I have also wrote a "driver" in assembly to perform some tests on an emulator. The code have been optimized in size the most that I could do and now it can read raw key scans from joystick ports 1 and 2.
; PSG IO addresses PSGAD: EQU 0A0H PSGWR: EQU 0A1H PSGRD: EQU 0A2H ORG 09000h ld a,(PORTKB) ; ; Scan keyboard connected at Atari Joystick port ; ; Inputs: ; register A: 0=Connector 1, >0=Connector 2. ScanKB2600: and a ; set zero flag accordingly ; Save PSG Context ld a,15 out (PSGAD),a in a,(PSGRD) ld (SAVPSG),a ld hl, KBROWS ; Select Joystick port accordingly jr NZ, ScanCon2 ScanCon1: and 10111111b ; clear bit 6 (joy port 0) or 00010011b ; set bits 4, 1, and 0 (all rows unset) ld b,a ld c,a res 4,a ; row 0 (pin8) low, rows 1 and 2 (6 and 7) high res 0,b ; row 1 (pin6) low, rows 0 and 2 (7 and 8) high res 1,c ; row 2 (pin7) low, rows 0 and 1 (6 and 8) high jr ScanRow0 ScanCon2: or 01101100b ; set bits 6, 5, 3, and 2 ( joy port 1, all rows unset) ld b,a ld c,a res 5,a ; row 0 (pin8) low, rows 1 and 2 (6 and 7) high res 2,b ; row 1 (pin6) low, rows 0 and 2 (7 and 8) high res 3,c ; row 2 (pin7) low, rows 0 and 1 (6 and 8) high ScanRow0: ld e,a call SaveRow ScanRow1: ld e,b call SaveRow ScanRow2: ld e,c call SaveRow RestorePSG: ld e,(hl) ; hl now points to SAVPSG SaveRow: di ld a,15 out (PSGAD),a ld a, e out (PSGWR),a ; update register 15 ld a,14 out (PSGAD),a ; select register 14 in a,(PSGRD) ; read keys hhhh*741 or 11110000b ; mask unused bits ld (HL),a ; save keyboard state inc hl ei ret ; Variables ; keyboard rows hhhh#963, hhhh0852, hhhh*741 KBROWS: EQU 09800h ; PSG register 15 save state (overwritten at the exit) SAVPSG: EQU 09803h PORTKB : EQU 09804h ; 0 -> connector 0, 255 -> connector 1
