The Ninja Tap is an adapter that allows to use up to 4 joysticks per MSX port (MSX Wiki).
There is not much information available on such adapter, let alone the schematics.
I wanted to build a clone of such adapter then I have started to disassemble a driver code and translations of japanese documentation available to figure out the connections.
Pin MSX Joystick | Function |
6 | goes to PARALLEL/!SERIAL of all 4021s |
8 | goes to CLOCK of all 4021s |
7 | receives the inverted level of signal from pin 8 (see oddity below) |
1 | receive the data out from the first tap port |
2 | receive the data out from the second tap port |
3 | receive the data out from the third tap port |
4 | receive the data out from the fourth tap port |
5 | is the VCC (5 Volts) |
9 | GND |
Protocol
The adapter uses four CD4021s to shift in the controller data from the four controllers:
disassembling the GETNIN function :
The sequence for reading the 4021s is the following
0) the sampling start with pin 8 (CLOCK = HIGH) and pin 6 (PARALLEL/!SERIAL = LOW)
- pulse (go high, then low) the PARALLEL/!SERIAL line (pin 6). That will latch the input of the keys to the 4021 internal flip flops. Notice that the CD4021 output is already loaded at the Q8 output.
- Pulse (go high, then go low) the CLOCK line (pin 8). (note: If this pin weren't initialized high, the first bit would be missed)
- shift in one data bit from TAP 1 at the UP line (pin1) into register H
- shift in one data bit from TAP 2 at the DOWN line (pin2) into register E
- shift in one data bit from TAP 3 at the LEFT line (pin3) into register D
- shift in one data bit from TAP 4 at the RIGHT line (pin4) into register C
- Repeat steps 2 through 6 for until all 8 bits are read
- Process the data.
The sequence of bits is the same used by NES controllers, being possible to make an adapter that uses 4 NES controllers with only one inverter (which makes me wonder to reuse a JoyMega adapter to create a Ninja Mega Adapter)
Oddity
The adapter was designed to be detectable by the driver, and uses the inverted state of signal at pin 8 which is applied to pin 7. The driver flips the state of pin 8 and check if inversion occurs on pin 8.
The problem is that pin 7 is an open collector and the detection routine pulls this pin down (instead of let it float ) during the detection, which means that the external inverter will have to fight (and win) against the internal 7407 open collector gate, otherwise the detection will fail.
Here's the code
;====================================== ; Connection Check Sub. ; return with B=B+1 if no hardware detected ; otherwise return with B=B+4 if hardwar detected CHECK: CALL PORSEL ; INC B ; B = Max player number + 1 AND 0C0H ; A is state of port 15. OUT (0A1H),A ; 678=L for both joystick ports (!) EX AF,AF' ; save state of Reg15 with all output pins low LD A,14 ; select register 14 OUT (0A0H),A IN A,(0A2H) ; read state of joystick port AND 20H ; 7=H ? return if bit is high (!) (shouldn't be forced high, its being driven low internally ) RET Z ; if return here, A = state of pin 6, and B=B+1 from the function call LD A,15 ; select register 15 OUT (0A0H),A EX AF,AF' ; restore state of Reg15 with all output pins low OR 030H ; make bits 4 and 5 high (pin 8 of both pulse pins) OUT (0A1H),A ; 8=H for both output ports LD A,14 ; select register 14 OUT (0A0H),A IN A,(0A2H) ; read inputs AND 20H ; 7=L ? is pin 7 low JR NZ,CHECK1 ; no, return with A=0 INC A ; Complement bit 0 of register A (read from pin 6) INC B ; B = B+3 INC B INC B RET ; No NTAP CHECK1: XOR A RET
