wesp32 PoE board not working
mmmunir966 wrote 12/01/2022 at 10:56 • -1 pointHi,
I have 3 brand new boards wesp32 PoE with revision 7 at my desk. One of them works fine, but the other two are not working. I am getting the error "Serial data stream stopped: Possible serial noise or corruption".
The other board is programmed, but does not run in normal mode and throws error "
rst:0x1 (POWERON_RESET),boot:0x3 (DOWNLOAD_BOOT(UART0/UART1/SDIO_REI_REO_V2)) waiting for download"
How I can make fixes of these?
ask
The error message you're encountering, "Serial data stream stopped: Possible serial noise or corruption," indicates that there might be an issue with the serial communication between your computer and the ESP32 boards. This error can occur due to various reasons, and troubleshooting steps are needed to identify and resolve the problem. Here's a step-by-step approach to help you diagnose and address the issue:
Check Physical Connections:
Make sure the USB cables connecting the ESP32 boards to your computer are secure and not damaged.
Ensure that the boards are properly powered and connected.
Update Drivers:
Ensure that you have the latest USB drivers installed for the ESP32 boards, especially if you're using a specific USB-to-Serial converter. <a href="http://sassastatuscheck.co.za/">converter</a>
