Had some trouble compiling the openOCD version for the picoprobe on the M1 macbook. This is based on a thread on github and the official guides, plus some blog posts that basically copied from each other.
https://github.com/raspberrypi/openocd/issues/7
#install additional brew libraries
brew install libtool automake texinfo wget gcc pkg-config libusb
# some path magic so compilers know where to look for stuff
export PATH="$(brew --prefix)/opt/texinfo/bin:$PATH"
# download openocd files with picoprobe branch
git clone https://github.com/raspberrypi/openocd.git \
--branch picoprobe --depth=1
cd openocd
./bootstrap
# this enables the picoprobe and deactivates other modules that fail to compile otherwise
CAPSTONE_CFLAGS="-I$(brew --prefix)/include" \
./configure --prefix="$(brew --prefix)" \
--enable-picoprobe --disable-presto --disable-werror --disable-openjtag
make -j4
# this will probably overwrite your current installation
# and will break openjtag
make install
# optionally remove the installation folder
cd ~/git
rm -rf openocd
