The default display orientation for the Android interface on the Forlinx Embedded i.MX8MP platform is landscape, but some products may require a portrait display. To address this requirement, Forlinx Embedded provides the following methods for modification:
The Android system controls the screen orientation through the persist.vendor.orientation property, which can have values of 0, 90, 180, or 270.
Configuration path: frameworks/native/services/su**ceflinger/Su**ceFlinger.cpp
Modify in processDisplayHotplugEventsLocked:
Su**ceFlinger::processDisplayHotplugEventsLocked() {
continue;
+ /* Rotate desktop */
+ char rotationvalue[PROPERTY_VALUE_MAX] = "";;
+ property_get("persist.vendor.orientation", rotationvalue, "-1");
+ int rotation = atoi(rotationvalue);
+ ALOGI("Primary Display Orientation is set to rotation %2d.", rotation);
+ switch (rotation) {
+ case 0:
+ internalDisplayOrientation = ui::ROTATION_0;
+ break;
+ case 90:
+ internalDisplayOrientation = ui::ROTATION_90;
+ break;
+ case 180:
+ internalDisplayOrientation = ui::ROTATION_180;
+ break;
+ case 270:
+ internalDisplayOrientation = ui::ROTATION_270;
+ break;
+ default:
+ break;
+ const DisplayId displayId = info->id;
const auto it = mPhysicalDisplayTokens.find(displayId);
After modification, you need to add the relevant configuration in the environment variable.
Path: device/nxp/imx8m/evk_8mp/system.prop
persist.sys.timezone=Asia/Shanghai persist.sys.language=zh persist.sys.country=CN +persist.vendor.orientation=90
Rotate 90 degrees here to write 90, 180 degrees to write 180, 270 degrees to write 270.
If you encounter a failure to set the value of a property:
Add the followings in device/nxp/imx8m/sepolicy/property_contexts;
+persist.vendor.orientation u:object_r:debug_prop:s0 vendor.wc_transport. u:object_r:vendor_wc_prop:s0 persist.vendor.usb.config u:object_r:vendor_usb_config_prop:s0 vendor.usb.config u:object_r:vendor_usb_config_prop:s0
forlinx embedded
