What is the best and fastest affordable analog scope ?
Yann Guidon / YGDES wrote 11/17/2016 at 17:20 • 0 points
Hello,
after a heart-shredding experience with a 11302 scope (found cheap on eBay then broken during shipment) I'm left with little money and no fast scope.
The 11302 is the fastest scope I have found, it's modular and can reach 500MHz (I got one with a 1GHz amplifier: 11A71 module). I don't care about DSO (unless it's an extremely expensive one, which I can't afford). And even 500MHz might not be fast enough as I start to push transistors in the GHz realm.
I'm sure there are analog 1GHz scopes but that's from an ad in an old magazine. There is a limit due to input impedance but at these frequencies, there is no point in 1M or 10M probes.
What should I do ?
* Chase another 11302(A) and hope it can see something at 1GHz ?
* Give up and settle for a 2467B ? (4×400MHz is still nice and the 2465 is a pleasure to work with)
* Find a >10Gsps DSO ?
* .... Design mine ?
