Need advise for a small alternator
manamana wrote 01/07/2017 at 17:39 • 0 points
Hey guys,
I'm developing a micro wind turbine as hiking/field-research eqipment. My problem is to find a fitting alternator:
-Since the rotor diameter is just half a metre (rel. high rpm) I'd like to work without a gearbox.
- necessary output of: 1W @ 560rpm; 6.3W @ 1000rpm; 40W @ 1850rpm (max. 30W also ok)
- right now I'm testing a 24W servo motor from "Japan Servo Co." but it gives just 6V output @ 3000rpm, about 3V @ 1500rpm --> It needs a very low resistence to get some energy out of it and it's definitely below the power curve of the turbine.
- brushless motors mostly have very high kv values and are therefore not useful without gearbox
So, I need advise where or how to find a good solution for a good price.
