Need help with passive component selection as part of a relay project.
Starhawk wrote 01/28/2017 at 17:26 • 2 points
I have built a circuit that doesn't work. (This is not unusual for me.) The circuit uses relays to count pulses from an old rotary phone dial... or is supposed to. I'm using a combination of the following circuits from http://www.electronixandmore.com/projects/relaycomputertwo/index.html (their images, not mine)...
I'm using a 22uF electrolytic cap and 10k 1w resistor, per suggestion, for the "duty length" adjuster in the second image. However, where this guy is using 24vDC, I'm using 12vDC. Result: that cap/resistor network blocks the pulses from continuing on. Obviously the values there need adjusting.
I've got JD1914 "80A universal auto" SPDT relays for everything except the 3PDT and 4PDT relays, for which I've used Omron MY4N-J relays. Everything is 12v, known good, and from eBay. Outputs are to indicator lamps (*NOT* LEDs!), the 12v "Jumbo Red Lamps" that Radio Shack sold before it died and became part of Sprint. I have an additional JD1914 relay wired in as a momentary power-cut, so that when the user presses a button, it resets the entire circuit. (I've tested that functionality and it is not at fault here.) Power comes from a well-used Gateway brick rated 12vDC 3.5a. Back-of-the-envelope calculation says that that's plenty of power... JD1914 relays, as near as I can find, use ~125mA coil current each (I have seven in the circuit, including the reset relay), and the Omrons are rated 91mA at 12v each (I have six). I don't have specs for the lamps but they can't be too bad...
Can anyone do the math to tell me what cap and resistor I need, to replace the ones in that network? I don't have much money (I buy everything from eBay because it's cheap)... certainly I've not got enough for a multi-value box setup of any kind... I can upload the wiring diagram later (and plenty of construction photos, if anyone wants) -- right now it's a PDF; I just need to make it a JPEG before I can upload it.
