Advices/infos about USB-connected
Yann Guidon / YGDES wrote 04/09/2017 at 01:42 • 0 points
Hello all,
I just received a couple of USB-capable devices (merci eBay !) and I'm trying to make them talk to my Linux-based computer.
Mastech MS8250D : a good-looking handheld multimeter (I needed to replace my 15yo Wavetek)
1254400.843474] usb 2-1.2: new full-speed USB device number 32 using ehci-pci
[1254400.923681] usb 2-1.2: New USB device found, idVendor=10c4, idProduct=ea60
[1254400.923687] usb 2-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[1254400.923690] usb 2-1.2: Product: CP2102 USB to UART Bridge Controller
[1254400.923694] usb 2-1.2: Manufacturer: Silicon Labs
[1254400.923696] usb 2-1.2: SerialNumber: 0001
[1254400.926106] cp210x 2-1.2:1.0: cp210x converter detected
[1254400.927227] usb 2-1.2: cp210x converter now attached to ttyUSB0
So it's apparently easy to connect, the interface chip is well known but the data format is weird. I setup the port with wild guesses:
stty 1200 cs8 raw -echo -echoe -echonl -echoprt -echoctl -echoke -parenb -F /dev/ttyUSB0
od -An -v -w1 -t x1 /dev/ttyUSB0 shows a constant stream of bytes that are cryptic but repetitive, and vary with the measured voltage. Maybe @Alain Mauer can help ?
At 1200baud, I detect a repetitive pattern of 9 bytes: here with no input in DC Volts
00 20 85 a1 24 01 00 00 00
from time to time I see transmission errors...
The pattern changes when I change the input voltage.
Axiomet AX6002P programmable lab PSU : A pretty nice cheap system, but a definite plus for my lab !
I only have "analog" PSUs and this one can set the voltage easily :-) It features a RS232+USB connector, and the documentation gives some hints about the parameters : 9600, 8N1
I found the manual of the following model (the more capable 6003P, that handles 3A instead of 2, and with LCD instead of LED display) and it mentions SCPI.
TTY=/dev/ttyACM3
stty 9600 cs8 raw -echo -echoe -echonl -echoprt -echoctl -echoke -parenb -F $TTY
the command echo -n "*IDN?" > $TTY returns the string "KORADKA6002PV2.0"
weird though : SCPI says that commands end with \n or \lf\n, but I only got the response with the "-n" option of echo, which doesn't send a newline char... And no other standard command seems to  be recognised ? and the vendor string is unknown to Google...
Really I don't want to use Windows and install their crappy software because that would not let me use the tools as I intend - I don't need a fancy useless buggy interface when I already have the tools in hand, I want to script and use both the multimeter and PSU at the same time, not separately... What's the point otherwise ?
Help...
thanks ;-)
