Forlinx Launched FET3576 System on Module powered by the Rockchip RK3576 processor!
FET3576-C system on module(SoM) is powered by the Rockchip RK3576 processor. This high-performance, low-power, feature-rich application processor is tailored for the AIoT and industrial markets. With 4 x ARM Cortex-A72 and 4 x ARM Cortex-A53 cores, plus a built-in 6TOPS NPU, it enhances your AI applications. Featuring board-to-board connection design for easy setup, it’s rigorously tested in Forlinx’s lab for stability in industrial conditions. With a 10 to 15-year life-cycle, ensure continuous supply.
Rockchip RK3576 SoM Features:
• 8nm processing technology;
• 4x 100-pin board-to-board connectors to maximize processor performance;
• Compatible design with FET3588-C;
• Firewall supports device access control and priority management;
• H.265 decoding up to 8K resolution;
• Multiple display interfaces: HDMI/eDP, MIPI DSI, Parallel, EBC, DP;
• Supports three displays working together with different content;
• Various high-speed peripherals: PCIe 2.1, USB 3.2, CAN-FD, etc.
forlinx embedded
