Recently, NXP (NXP Semiconductors) i.MX 6 series processors have been added to its "NXP's Product Longevity Program", which extends the lifecycle of different processor models by 10 to 15 years, ensuring long-term stable supply and maintenance.
(The purpose of NXP's Product Longevity Program is to provide stable chip supply for customers' embedded products. The NXP's Product Longevity Program for specific products means ''NXP will at least support this product for a specified period,'' and in special cases, the supply duration can be extended.)
As a gold partner of NXP, Forlinx Embedded has launched 7 SoM products based on 4 processors from the i.MX 6 series, with various temperature ranges and connector types, offering more flexible options for customers. These products are currently widely used in fields such as artificial intelligence, industrial IoT, energy storage, smart transportation, medical equipment, charging stations, consumer electronics, and HMI, and have gained the trust of thousands of customers.
Thanks to NXP's Product Longevity Program, the supply lifecycle of Forlinx Embedded's i.MX 6 series SoMs has also been further extended, providing customers with more durable and stable product support.
i.MX6UltraLite (NXP's Product Longevity Program Until 2035)
Folinx Embedded FETMX6UL-C SoM
Designed based on the NXP i.MX6UltraLite processor with Cortex-A7 architecture and a clock frequency of 528MHz. It uses two sets of high-quality 80Pin board-to-board connectors. Rigorous temperature range testing ensures stable operation in environments from -40℃ to +85℃, supporting up to 8 x UART, 2 x Ethernet, and 2 x CAN industrial bus interfaces. It is available in industrial and commercial versions, providing users with more options.
i.MX 6Quad(NXP's Product Longevity Program Until 2035)
Folinx Embedded FETMX6Q-C SoM
Designed based on the NXP quad-core ARM Cortex-A9 processor with a clock frequency of 1GHz and 12-layer PCB gold-plated technology. The overall board size is only 40mm x 70mm and features four 1.5mm high connectors with up to 320 pins, exposing all processor function pins. It comes with rich carrier board resources, including Gigabit Ethernet, CAN-bus, camera, Wi-Fi & Bluetooth, as well as MIPI, MLB, EIM BUS, and other CPU-specific functions.
Folinx Embedded FETMX6Q-S SoM
Also based on the NXP i.MX 6Quad processor, this version uses 8-layer PCB gold-plated technology with better electrical characteristics and anti-interference properties. The board has 220 pins (55*4) and measures 60mm x 60mm, offering a square structure design for easier carrier board layout.
i.MX 6DualLite (NXP's Product Longevity Program Until 2035)
Folinx Embedded FETMX6DL-C SoM
Designed based on the NXP dual-core ARM Cortex-A9 i.MX6DualLite processor with a clock frequency of 1GHz and 12-layer PCB gold-plated technology. The board is compact at 40mm x 70mm, featuring optimized fixed holes and anti-misplug design, with four 1.5mm high connectors and up to 320 pins, exposing all processor function pins. It comes with abundant carrier board resources, including Gigabit Ethernet, CAN-bus, camera, Wi-Fi & Bluetooth.
Folinx Embedded FETMX6DL-S SoM
Also based on the NXP i.MX6DualLite processor, this board uses 8-layer PCB gold-plated technology. The stamp hole connection method provides better electrical characteristics and anti-interference properties. This SoM is a minimal system with an integrated LCD interface, eliminating the need for a carrier board and enabling immediate startup and debugging, reducing development difficulty. FETMX6DL-S SoM is available in industrial and commercial versions for more options.
i.MX6ULL
Note: i.MX6ULL processor was released in 2016 with a 15-year supply period, and its product longevity has not yet been extended.
Folinx Embedded FETMX6ULL-C SoM
Developed based on the NXP i.MX6ULL processor, using the low-power ARM Cortex-A7 architecture, with a clock speed of up to 800MHz. It natively supports 8 x UART, 2 x Ethernet , 2 x CAN-bus, 2 x USB 2.0, LCD, and other common interfaces. It is compact at 40mm x 29mm and uses 2mm high board-to-board connectors, combining small size and easy disassembly.
Folinx Embedded FETMX6ULL-S SoM
Also based on the NXP i.MX6ULL processor. It supports industrial, wide-temperature, and commercial configurations, offering users different choices. It uses 8-layer PCB gold-plated technology for better electrical characteristics. Compact size of 44mm x 35mm with a stamp hole package design.
Forlinx Embedded's embedded intelligent main control products are carefully designed and optimized to balance functionality and cost, providing flexible and efficient solutions for various embedded applications. Whether for high-performance applications or cost-effective projects, Forlinx Embedded's i.MX 6 series SoMs can handle both, accelerating your project development and product launch.
forlinx embedded
