In this era of rapid technological advancement, an amazing product — RK3568 System on Module (SoM) has emerged.
✨It is equipped with Rockchip’s new — generation AIoT processor RK3568, which is a 64 — bit quad — core Cortex — A55 System on Chip (SoC) based on the advanced 22nm process technology. The built — in Neural Processing Unit (NPU) has a processing performance of up to 1TOPS.
Network models based on a series of frameworks such as TensorFlow, MXNet, PyTorch, and Caffe can be easily converted, and it also supports RKNN — Toolkit. At a running speed of up to 2.0GHz, it still maintains excellent low — power performance.
🎯In terms of graphics processing, the 38.4GFLOPS 800MHz GPU Mali — G52 performs outstandingly.
🎥The video codec capabilities are extremely powerful. It supports 4K resolution H.264, H.265, VP9 and other formats of high — definition hard decoding. It can support the decoding of multiple video sources simultaneously and also supports HDR10 with excellent color and dynamic range performance. At the same time, it supports H.264 and H.265 format hardware encoding at 1080p60fps and can adjust the dynamic bit rate, frame rate and resolution.
📺There are various display interfaces, including HDMI (up to 4K output), LVDS, MIPI — DSI, RGB, eDP, etc., which can support three — screen synchronous / asynchronous playback. It is perfectly suitable for fields such as PDAs, cash registers, multi — screen advertising machines, karaoke machines, electronic bus stop signs, and self — service machines.
🖥Multiple high — speed interfaces make it even more powerful, including 2 USB3.0, 2 PCIE3.0, 3 SATA3.0, 2 1000Mbps Ethernet (GMAC), 3 CAN — FD, and 10 UART.
🛡After undergoing harsh ambient temperature tests, stress tests and long — term running tests, the FET3568 — C SoM has been proved to be robust and reliable. It is widely used in multiple fields such as medical, industrial, transportation, cloud terminal, streaming media, security, AI application, and energy management.
Whether you are looking for high — performance, multi — interface or stable and reliable devices, Rockchip RK3568 SoM will be your ideal choice. Come and explore its infinite possibilities!
forlinx embedded
