cheap and hacker friendly plug and cable system
draufunddran wrote 01/02/2025 at 10:11 • 0 pointsDoes anyone have a suggestion on hacker friendly plug and cable systems? I want to create weather station central box with different sensors connected to it. I could just hardwire them but I want to have I semi modular and remove and plug different sensor to the box. Does anybody have any suggestions?
Thanks in advance!
Flo
I would also recommend JST connectors for most purposes inside an enclosure or on a plain PCB. I found JST-PH connectors to be particularly useful as they are the smallest JST connector which can be crimped by hand even without specialised tools just narrow pliers and a magnifying lamp.
For external connectors go for something where panel-mounted versions are available.
I would recommend:
Barrel jacks for low-current DC power, XT family connectors (like XT60) for high current DC power, also a good idea is to hijack an old USB cable from a mouse for an easy-going 5V power supply from a powerbank or wall charger.
3.5mm audio jacks for low wire count interfaces like UART consoles, 1-wire
RJ-45 or DE-9 (aka DB-9) + cat 5e cable for where you need more wires or a twisted differential pair, think CAN bus, RS-485/MODBUS. These should also work for I2C or SPI although I have not used those in external connector situations.
The above list prioritises connectors which are round (easier to install on a panel or enclosure) and have a large amount of cheap/scrap cables, plugs and receptacles.
For a quick/simple prototype, screwless spring terminals or screw terminal blocks, for something more plug and play but a little more work Dsub-9 (DE-9) - super reliable and super cheap, available as waterproof, pcb or panel mount, solder or crimp, any other option you could want
I would just use terminal blocks - think the kind that have a PCB-side receptacle connector and a removable plug with screw terminals. They have a more secure fit than Dupont headers, no crimping tools required, and they're common/relatively cheap on Digi-Key.
I vote for RJ-45.
0.1" header pins are most common for the hobbyist, and cheap to obtain, but not always the most reliable connection. I like JST-GH for the locking, and small size! You can see some example part numbers used in this connector standard: https://bluerobotics.com/learn/wl-connector-standard/#ethernet-10100
Depending on who will do the plugging/unplugging, the most user friendly way would be USB-C ports and cables. Even non-technical people know how to use them and won't screw up orientation.
People will propably hate me for that (long distance I2C yadda yadda i know), but i would stay with something like a JST-PH connector and using an adafruit pinout.
I built some sort of vending machine once just daisychaining everything together (plus extra power via XA-connectors). Also these cables are common and realtively cheap and you can combine them with lots of existing sensor modules.
Or just use screw terminals.....
