Dell Front USB-C
stanislas-bertrandStanislas Bertrand wrote 02/04/2025 at 06:03 • • 2 min read • Like
Repurposing Dell USB-C front connector.
I got a USB front panel connector going to a USB 3.0 Motherboard connector from a Dell computer.
The cable had a USB 3.0 type A and USB 3.0 Type-C receptacles. There was also a dual USB 3.0 Type A receptacles to USB 3.0 motherboard connector.
I got an adapter cable to see if I could make use of the Type-C receptacle. The adapter only worked for the dual Type-A front panel connector.
I found this post which mentioned a different pinout for the 20 pin motherboard connector.
Indeed the VBUS does not go to the right pins. Using a USB-A cable pigtail, I validated the following connection on the 20 pin cable ( not motherboard ).
USB-CPin #Pin #USB-A
SS Rx-1/Key
SS Rx+219SS Rx-
GND318SS Rx+
SS Tx-417GND
SS Tx+516SS Tx-
GND615SS Tx+
D-714GND
D+813D-
VBUS912D+
VBUS1011VBUS
The above was confirmed by continuity testing for the USB-A receptacle ( pins 11 to 19).
I removed the 20 pin motherboard cable and connected a regular USB-A cable.
Overall the USB-C works, however PC->Device link seem to have some issue. Perhaps the power path is not able to carry the necessary current. Need to add additional VBUS / GND wire. Or perhaps the 5V VBUS was not too good for the ASM1464 chip.
The TYPE-C pinout is
Like
