When developing NPU (Neural Processing Unit) related applications on RK3568, compiling and running test programs is a crucial step. This article will take rknn_yolov5_demo as an example and guide through each step in detail.
1. Preparation: Locate the Compilation Script
Open external/rknpu2/examples/rknn_yolov5_demo/build-linux_RK3566_RK3568.sh
2. Key Configuration: Modify the Cross-Compilation Toolchain Path
After opening the build-linux_RK3566_RK3568.sh file, modify the GCC_COMPILER to the path of the cross-compilation toolchain and save the file.
3. Compile the rknn_yolov5_demo Program
In the terminal command window, navigate to the rknn_yolov5_demo folder:
cd external/rknpu2/examples/rknn_yolov5_demo/
Run the build-linux_RK3566_RK3568.sh script to compile the program:
./build-linux_RK3566_RK3568.sh
4. File Transfer: From Local to Development Board
Copy the contents of the install directory to the development board.
5. Navigate to the Correct Directory: Preparing to Run the Program
Navigate to the corresponding directory on the development board.
6. Set the Library File Path
export LD_LIBRARY_PATH=./lib
7. Run the Program to Identify Object Categories in the Image
The command format to run the program is: ./rknn_yolov5_demo
./rknn_yolov5_demo ./model/RK3566_RK3568/yolov5s-640-640.rknn ./model/bus.jpg
8. View the Results
Finally, copy the resulting image generated on the OK3568-C development board to local computer and view it. This way, the program's object recognition results in the image can be visually observed, the accuracy of the recognition can be checked, and the performance of the NPU test program can be evaluated.
By following these detailed steps, the rknn_yolov5_demo NPU test program on RK3568 can be successfully compiled and run. It is hoped that this article will be helpful for the development work.
forlinx embedded
