Learn ‘how to connect Cricut via Bluetooth’. In order to setup any Cricut machine on your phone or computer, laptop it is essential to connect the device to your machine. You can choose either a phone or a computer for this. If you have a desktop, it must be either a Windows or Mac. An Android or iOS device is required for mobile devices. Once you have one of these things, you can connect it to your machine with Bluetooth. After successfully connecting, you can proceed with the rest of the setup and start working on your projects. So, without any further delay, let’s start with the connection process.
How to Connect Cricut via Bluetooth on Mac System?
A Mac computer is an excellent computer for using the Design Space app on it. The computer is compatible with the app, and you can easily download it. You just have to make sure that you are using a macOS 11 or later version of the operating system on your computer. These are the steps for downloading the app on your MacBook.
- First, turn on your computer. To do so, connect it to an electric socket with the help of a power adapter, and after that, press and hold the power key.
- Keep in mind that the distance between the computer and your machine should be less than 10-15 feet.
- Now, open the Apple menu on the computer and go to the System preferences.
- After that, you have to go to Bluetooth settings and turn it on.
- Once you turn on Bluetooth on your computer, you will see that all the devices that are available to be connected to your computer appear on the list. You have to click on your machine, and you will be able to connect them.
- Now, the connection between your machine and the computer has been established.
- To confirm the connectivity on your computer, go to the app and open New Product Setup. You will see there that they are connected.
How to Connect Cricut via Bluetooth on a Windows?
A Windows commuter is equally good to use with a crafting machine. To work on a Windows PC, you need to connect it to a machine with the help of Bluetooth. Below are the steps to follow:
- Turn on the machine and keep it closer to your computer, within 10-15 feet.
- Then, open the Start menu on the computer, go to Settings, and click the Devices option.
- Next, open the Bluetooth on the computer and turn it on.
- After that, click on Add Bluetooth or other device.
- Now, choose the Bluetooth option and wait until the computer detects the machine.
- Upon seeing the machine, you have to click on it, and it will connect.
- Once you connect the machine, you can make sure of it by going to the Design Space app.
How to Connect Cricut via Bluetooth on an Android Device?
Instead of a computer, a phone can also be a good option for connecting it to a crafting machine. To connect your Android device to a machine, you have to follow these steps:
- Start by powering the machine and keeping it within 10-14 feet.
- Then, go to your phone’s Settings and then open Bluetooth.
- If the Bluetooth on the phone is off, you will have to turn it on.
- Once you turn on the Bluetooth, you have to search for the machine, and you will have to tap on it upon seeing that.
- Very soon, the phone will connect to your machine via Bluetooth.
- In the last step, you can continue with the steps to set up your machine on an Android phone.
How to Connect Cricut via Bluetooth on iPhone?
An iPhone is also good for working on a machine. You can connect the phone to your machine via Bluetooth and make projects however you want. The steps you have to follow for that are in the section below:
- Just like you with any other device, start by giving the machine a power supply so that you can turn it on by pressing the power button.
- Once the machine is on, it is going to connect to your phone.
- Now, go to your phone’s settings and turn on Bluetooth.
- Then, search for your machine, and you will see it appear on your screen.
- When it appears, you need to tap on it, and it will connect to your phone.
- You can go back to the app and ensure the wireless connection.
FAQs
Is Cricut Machine Bluetooth Enabled?
Yes, it is! If you are using the latest machine, then you should not be worried about whether your machine has a Bluetooth connection option or not. All the latest machines are built-in with Bluetooth. You can easily connect them to your device and use them for your projects.
How Can I Connect Cricut to a Computer?
To connect your machine to your computer, you have to do as follows:
- First of all, turn on the machine.
- Then, keep it within 15 feet of the computer.
- Next, go to the settings and turn on Bluetooth.
- After that, select a Bluetooth device option and search for it.
- When you see your machine, click on it. It will be connected to your computer.
Do I Need an External Bluetooth Adapter for My Cricut Machine?
Whether you need an external Bluetooth adapter or not will depend on the type of machine you are using. If you are using one of the oldest Cricut machines that are not built with a Bluetooth connection, you will need an external Bluetooth adapter. But if you are using one of the latest models that are already enabled with Bluetooth, you will not need an external Bluetooth adapter. You can simply connect them via Bluetooth and get ready to work on it.
Visit: cricut.com/setup
install cricut design space app
Source: https://cricuthelpsupport.wordpress.com/2025/03/17/how-to-connect-cricut-via-bluetooth-full-guide/
cricut design space
