Learn “how to make stickers with Cricut“. To do so, you need to download the Design Space app on your device. The sticker creation feature in Cricut Design Space is available exclusively to Cricut Access subscribers. Anyone can preview this tool by clicking on “Make It” on their project.
Before we dive into the how-to, let’s talk about why. Making your own stickers is not just creative and fun – it’s also a way to save money, personalize gifts, grow your brand, or start a small business. Whether you’re customizing packaging or decorating laptops, Cricut’s Print Then Cut feature gives you full control over every detail, from design to execution.
Essential Supplies for Creating Custom Stickers
Cricut printable sticker materials are compatible only with inkjet printers. Using a laser printer can damage the materials or the printer. You require the following supplies for making your stickers:
- You will need a Cricut machine that supports the Print Then Cut feature.
- The latest Cricut Design Space software is installed on your computer or mobile device.
- Fine-point blade and housing
- An inkjet printer that supports AirPrint or mobile printing.
- Scraper tool
- LightGrip machine mat
Note: The Explore, Maker, Venture, and Joy Xtra machines are compatible with the Print Then Cut feature. The Cricut Joy is the only model that does not support Print Then Cut.
How to Make Stickers With Cricut: Easy Steps
Making stickers with Cricut is the fastest and easiest way ever. To do so, you need to open your Design Space. Then, follow the steps given below:
Step 1: Use any combination of images and text.
Step 2: Select an image from the Design Space library or upload your own.
Step 3: Choose an image on Canvas.
Step 4: On the top edit bar, click on the Create Sticker button (For Windows).
Choose the Edit option and then click the Create Sticker option (For mobile devices).
Step 5: Now, your screen will prompt you to choose your cut style. You can choose to die-cut or kiss-cut, depending on your convenience.
- Die Cut – It cuts around your design all the way through the material and liner.
- Kiss Cut – It cuts through the printable layer only, leaving the liner intact.
Step 6: It’s time to customize the color and thickness of your sticker’s border.
Step 7: If you have selected Kiss Cut, you will have the option to add a Die-Cut Edge. This will add an easy-peel border that cuts all the way through the liner. This makes it easier to hand out individual stickers, as they can be easily peeled from the liner.
Step 8: Next, click the Apply button when you’ve made all your selections, as shown in the image below.
Step 9: If you make any adjustments, locate and re-enable the Create Sticker tool, now labeled as “Edit Sticker.” Click on it.
Step 10: Select Make and follow the instructions in Cricut Design Space to print your sticker.
Step 11: If you haven’t completed the Print Then Cut calibration yet, you will be prompted to do so at this point. Use regular printer paper and follow the instructions to complete the calibration. Only then can you continue with your stickers project.
Step 12: If you want multiple copies of your sticker, you can use the Project Copies optionon the Mat Preview to increase the number of copies.
Step 13: Select Browse All Materials, then choose the specific material setting that will be listed under the Compatible tab.
If you have a Cricut Explore Air 2 or an older model, first turn the Smart Set dial to the “Custom” setting.
Step 14: Now, it’s time to place your printed sticker material on a LightGrip cutting mat and load it into your machine. Place the printed vinyl and laminating sheet on the LightGrip machine. Ensure that the page is oriented on the mat as it appears in Cricut Design Space.
Step 15: Press Go, and the machine will accurately cut your design. Your machine will scan for the Print Then Cut sensor markings and cut your design out precisely.
Step 16: Press Unload when the cut is complete.
Make sure your project surface is clean and dry. Peel off the sticker from the liner by hand, place it on your project surface, and enjoy!
Now that you have explored the full step-by-step guide, you’re all set to start your own creative journey. Whether it’s for fun, business, or a personal touch to your gifts, knowing how to make stickers with Cricut opens up endless creative possibilities!
Frequently Asked Questions (FAQs)
Which Printer Is Best for Making Cricut Stickers?
Every inkjet printer works best for making stickers, but users have often recommended the Epson EcoTank ET-2800 printer. It is an excellent choice for those living in a small home office environment who want to minimize their operational costs. It also offers a manual double-sided printing feature, along with a Bluetooth wireless capability that enables printing from your phone.
What Is the Main Difference Between a Kiss-Cut and a Die-Cut?
The main difference between a kiss-cut and a die-cut lies in the depth of the cut. Kiss-cuts only cut through the top layer of material (like vinyl on a sticker), leaving the backing paper intact. Due to the intact backing, they are easier to peel and handle. Meanwhile, die-cuts cut through both the top layer and the backing paper, creating a sticker with the exact shape of the design. This is ideal for branding and promotional purposes, where a professional and clean look is desired.
Do I Need a Cricut Access Plan to Use the Create Sticker Feature?
Yes, you need a Cricut Access subscription to use the Create Sticker feature in Cricut Design Space. While anyone can preview and experiment with the Cricut Sticker feature, a subscription is required to cut and use the actual stickers. If you don’t have Cricut Access, start your free trial today – it has features like automatic background removal and premium content.
Visit: cricut.com/setup
Source: https://mycricut-design-app.com/how-to-make-stickers-with-cricut-easy-steps/
williamwilsond32
