Losing data from an external hard disk can be frustrating. Whether it’s photos, documents, or work files, data loss often feels serious. However, recovery is often possible if you follow the right steps. This guide explains common causes of data loss, ways to recover data, and how to prevent it from happening again.
Causes of Data Loss
Data loss can happen for several reasons:
- Accidental Deletion: Files deleted or drives formatted by mistake.
- File System Corruption: Happens when a drive is unplugged improperly or due to crashes.
- Physical Damage: Mechanical failure or damage from drops, heat, or moisture.
- Malware: Viruses that delete, corrupt, or encrypt files.
- Power Problems: Power surges or outages damaging the drive.
Knowing the cause helps decide the best recovery method. Logical issues can often be fixed with software, while physical damage usually requires professional help.
Pre-Recovery Steps
Before attempting to recover data, take these precautions:
- Stop Using the Drive: Continued use risks overwriting lost files.
- Assess the Issue: Listen for unusual noises like clicking, which could mean physical damage.
- Check Connections: Try different cables and USB ports.
- Verify Detection: Make sure the drive shows up in your operating system’s file manager.
- Backup What You Can Access: If some files are visible, copy them immediately to a safe location.
Data Recovery Methods
Method 1: Check Hidden Files
Sometimes files are hidden by system settings or malware.
- Windows:
- Connect the drive.
- Open File Explorer, go to View > Options.
- Under the View tab, select Show hidden files, folders, and drives and uncheck Hide protected operating system files.
- Look for your files.
- macOS:
- Connect the drive and open Finder.
- Select the external drive.
- Press Command + Shift + . (period) to show hidden files.
If files are still missing, try the next method.
Method 2: Use Recovery Software
Recovery software, such as Stellar data recovery professional for windows helps restore files deleted or lost due to corruption.
How to use:
- Download and install the software on your computer’s internal drive or a different external device (not the affected drive).
2. Connect the external hard disk.
3. Run the software, select the drive, and start a scan. Use a deep scan if the drive was formatted or heavily corrupted.
4. Preview found files and recover those you need. Save recovered files to a different drive.
Free versions may have limits; paid versions offer full recovery options.
Method 3: Restore from Backup
If you have a backup, restoring data is simple:
- Connect your backup device or log into your cloud backup service.
- Use Time Machine on macOS or Windows Backup to restore files.
- Download files from cloud services like Google Drive or Dropbox.
- Confirm that the restored files are complete.
If you don’t have a backup, set one up after recovery.
Method 4: Professional Data Recovery Services
If the drive has physical damage or software recovery fails, professional recovery may be necessary.
- Choose a reputable company (DriveSavers, Ontrack, etc.).
- Request a free diagnostic quote.
- Send the drive following the company’s packaging instructions.
- Review the recovery report and approve the files you want.
- Receive recovered data on a new device.
Cost depends on damage and can range from a few hundred to thousands of dollars.
Use professional services when:
- The drive makes clicking or grinding noises.
- The drive is not detected by any computer.
- The data is critical and other methods have failed.
Tips to Improve Recovery Success
- Act quickly to reduce the risk of overwriting lost files.
- Do not save new data or install software on the affected drive.
- Use read-only recovery tools when possible.
- Avoid attempting physical repairs yourself.
- Try multiple recovery tools if one doesn’t work.
- Recover files to a different drive or storage device.
Preventing Future Data Loss
- Regularly back up data following the 3-2-1 rule: 3 copies of your data, on 2 different media types, with 1 copy stored offsite.
- Use backup tools like Time Machine (macOS), Windows Backup, or cloud backup services such as Backblaze.
- Always eject external drives safely through the operating system before unplugging.
- Keep antivirus software updated to protect against malware.
- Monitor drive health with tools like CrystalDiskInfo (Windows) or DriveDx (macOS).
- Handle drives carefully and store them in safe places.
- Use quality hard drives from trusted brands.
Conclusion
Recovering data from an external hard disk is often possible with the right approach. Start by checking for hidden files, then try recovery software or restore from backups. If the drive has physical damage or data is very important, professional recovery is the best option. Acting promptly and carefully handling your drive will increase your chances of success. To avoid future problems, maintain regular backups and follow safe handling practices.
Eric
