How does RISC-V works?
x-wangX. Wang wrote 09/12/2025 at 19:14 • 1 min read • Like
Are you a hardcore programmer? Then implementing a RISC-V processor on an FPGA is right for you. It involves using the programmable logic to create a "soft core" of a RISC-V CPU. Instead of using a fixed, off-the-shelf processor, designers can instantiate a RISC-V core, available as hardware description language code like Verilog or VHDL, within the FPGA.
The existing FPGA implementations are:
- RISC-V CPU: https://github.com/lnis-uofu/OpenFPGA
- Java VM: https://github.com/amal029/jop
We can implement GPU on FPGA, it can be effectively used for the custom hardware accelerators for graphics processing, offering advantages in low latency, and integration for specific applications.
Like
