How to Create Rhinestone Template With Cricut: Full Guide
williamwilsond32williamwilsond32 wrote 11/21/2025 at 12:09 • 7 min read • Like
Many crafters use Cricut Maker and Cricut Explore series machines to create rhinestone templates, a lesser-known but powerful feature. Magic Flock is a specialized ‘rhinestone template material‘ that allows you to transfer and adhere rhinestones easily. This material is known as flock or hotfix, and it is pressed onto your garment or fabric with a heat press.
how to create rhinestone template with Cricut
Get ready with your Cricut machine that can cut the rhinestone template material, especially in the Maker and Explore series. Whether you’re preparing for a custom project or looking forward to expanding your crafting skills, this guide will teach you ‘How to Create Rhinestone template with Cricut‘, with full step-by-step instructions.
Supplies Needed for Your Rhinestone Project
You will need the following supplies and tools for making rhinestone projects:
Important Note: Cricut Joy is not designed to create rhinestone projects.
How to Create a Rhinestone Template With Cricut
If you’re planning to create a rhinestone template with your Cricut machine, you must follow a structured approach. Follow this step-by-step guide to get optimal results at every stage.
Step 1: Choose or Design Rhinestone Pattern
The Cricut Design Space software doesn’t currently support rhinestone fills. You have two options:
Option A: Use a Pre-made Design
  1. Open Cricut Design Space and upload your pre-made design image or SVG file.
  2. Choose the Upload Image option and then Browse.
  3. Select your SVG file from your system and click Open.
  4. Insert the design onto the canvas.
Option B: Create Your Own
  1. Use the Shapes tool to create individual shapes and arrange these shapes in the desired pattern on the design.
  2. Add a rhinestone grid to your design.
  3. Adjust the spacing and size of the grid to match the size of your rhinestones.
  4. Place the design on the top of the grid.
Step 2: Resize Your Design
  1. Resize the font design so each circle has a diameter of 0.127 inches. Once this is achieved, you’re ready to proceed.
  2. Verify that each circle is correctly sized.
  3. Ensure all circle layers are set to Cut.
  4. Use Attach to keep everything in place during cutting.
  5. If you want the design to act as a template, you can use the Slice feature to cut the design from the rhinestone grid. You can use the Weld feature for the individual rhinestone shapes to create a single shape for cutting.
How to Install Rhinestone https://www.dafont.com/ app on windows
Note: Remember to mirror your design, especially when it contains text, to ensure proper orientation after pressing.
Step 3: Set Material Settings
  1. Tap on Browse All Materials and go to Material Settings.
  2. Click “Add New Material” and locate the green tab at the bottom of the screen.
  3. Name it as Rhinestone Flock, and then click Save.
  4. Select “More Pressure” and select the box to apply to all mats.
  5. Return to the cut screen.
Step 4: Cut the Rhinestone Template
  1. Now, place the flocked template material on a StandardGrip mat (sticky side down).
  2. Use a brayer tool to press the material onto the mat.
Cricut Standard Grip mat
  1. After that, ‘Click Go‘ to begin cutting.
  2. If you select “Felt” as your material setting in ‘Cricut Design Space‘, the mat may become cluttered with debris, as shown in the image.
Cricut Design Space Download
  1. Try selecting the flocked paper setting with less pressure. This will allow you to move the mat easily without making a mess.
  1. Consider using a double-cut setting to ensure a complete cut, especially for detailed designs.
  2. When you’re done with cutting, weed out all the tiny circles. This will leave behind holes where the rhinestone will sit.
Tip: If necessary, gently use a weeder or tweezers to remove any stubborn holes.
Step 5: Apply Rhinestones to Template
  1. Place your template and stick it to a clean, flat surface like a tray.
  1. Pour rhinestones all over the tray.
how to make rhinestone design with cricut design spacer app
  1. Then, brush the rhinestones until the holes are completely filled. If the sizes of your holes are just right, the rhinestone will stick into the right place.
  2. Shake off the excess rhinestones.
Step 6: Transfer the Rhinestone Design
  1. Cut a piece of rhinestone transfer tape (make sure it’s heat-resistant).
  2. Then, gently press the ‘transfer tape‘ over the design, pressing firmly to pick them up.
  3. Peel off the tape slowly, ensuring all stones are picked up properly.
learn-how-to-make-rhinestone-transfer-tape-on-Cricut-design
Note: This transfer tape is different from what we use for adhesive vinyl.
Step 7: Heat Press Your Design
  1. Wash and iron your fabric. Make sure it is clean and wrinkle-free.
  2. Place the tape with rhinestones on your garment or surface.
  3. Press for 15-20 seconds using firm pressure.
learn-how-to-use-cricut-heat-press-machine
  1. Peel the transfer tape while it’s warm.
Learn-how-to-download-Cricut-design-space-account
  1. Press the heat press again if you see that the rhinestones didn’t stick in place
  2. While the process involves a few technical steps, it can be done easily with the right tools and guidance.
And that’s it; your project is ready, and you’ve successfully learned ‘how to create rhinestone template with Cricut!
How to Make Your Rhinestones Last Longer
By considering these factors and following best practices, ensure that the rhinestone embellishments on Cricut projects are durable and long-lasting.
  • Use high-quality rhinestones: Opt for rhinestones that are well-made and resistant to fading or chipping.
  • Choose the right adhesive: Select an adhesive that is compatible with the material you are applying the rhinestones to, whether it’s heat-transfer vinyl or another surface.
  • Apply the rhinestones properly: Apply hotfix rhinestones or use a suitable glue and allow adequate curing time.
  • Store projects appropriately: Avoid exposing your projects directly to sunlight or harsh chemicals that could damage the rhinestones.
Frequently Asked Questions (FAQs)
What Is the Strongest Rhinestone Glue?
For the strongest bond on rhinestones, you can use E6000 Plus or Bob Smith Industries 2-part epoxy. These epoxy products are known for their industrial strength and durability. They are also water-resistant and suitable for various surfaces, such as fabric and hard surfaces.
However, you should be careful while using it, as it contains solvents that may damage acrylic or resin rhinestones. Therefore, it should always be used with glass rhinestones.
How long Do Rhinestones last?
The longevity of rhinestones depends on their quality and how they are attached. Lower-quality rhinestones are more prone to fading or chipping. Using a good adhesive or proper curing with gel can surely increase the lifespan of rhinestones, especially in nail art.
For clothing, using Cricut iron-on materials that are guaranteed to withstand up to 50 washes can help ensure the rhinestones stay adhered to the fabric. Exposure to sunlight or harsh chemicals can also make your rhinestones fade over time.
Can Rhinestones Rust?
No, rhinestones cannot rust because they are made of glass or plastic and do not contain metal. The most common issue with rhinestones is discoloration, as they sometimes turn black or yellow due to moisture or poor quality.
Moisture often gets trapped behind the rhinestone’s foil backing, causing blackening. Yellowing can also happen with lower-quality rhinestones due to the degradation of the resin used.
Will Resetting Cricut Machine Delete My Saved Projects?
No, resetting a Cricut machine will not delete your saved projects. Cricut Design Space saves all of your projects to the cloud, meaning they are stored on Cricut’s servers, not on your computer or the machine. Unless you’ve specifically changed the default settings to save only to your computer, your projects will be safe in the cloud even if you reset your machine. Therefore, resetting the machine will not affect your saved designs.
How Do I Reset my Cricut Machine to Factory Settings?
Learn How to Reset your Cricut to its factory settings, you need to follow the instructions given below:
  • First, turn off your machine (Cricut Explore/Maker/Joy) using the power button.
  • Then, find the Reset button on your Cricut Machine.
  • After that, press and hold it for at least 5-10 seconds.
  • Release the Reset button and turn the Cricut Machine back on.
Visit: cricut.com/setup
Source: https://mycricut-design-app.com/how-to-create-rhinestone-template-with-cricut-full-guide/
Like
