PVC Enclosure BOM (for version 3.2)
stephen-chaseyStephen Chasey wrote 11/26/2025 at 21:44 • 7 min read • Like
Tools you will need
ItemQuantityImage
110mm PVC pipe1 meter
50mm PVC pipe1 meter
(only need ~20cm)
110mm T-joint 45° 3x glue joint1
110mm T-joint 90° 3x glue joint
1
110x50mm eccentric adapter1
110x50x50mm eccentric adapter1
110mm straight joint1
110mm screw-on end cap2
50mm elbow joint 90° (male-female)2
50mm elbow joint 45° (male-female)1
50mm end cap2
3mm PVC sheet500x500mm
Ø~32cm plastic plant pot saucer1
transparency film (for printing - a section of PET from a plastic bottle would also work)3x3cm
Mast mount to fit 110mm PVC pipe1
Hose clamp to fit 110mm PVC pipe1
Hose clamp to fit 50mm PVC pipe1
Adjustable foot - 6-8cm3
Hanging plate1
20cm L brace
15cm L brace
10cm L brace
M3 2cm bolts, washers and nuts
M4 2cm bolts and nuts
1
1
1
2
6
M6 2.5cm bolts, washers and nuts4for the pole mount
2cm wood screws with countersink head
Velcro tape~15cm
Carpet tape~20cm
Duct tape~20cm
Matte black sparay paint1 can
Black shrink tubing - 3+cm diameter30cm
Like
