How to Make a Stencil With Cricut? (Complete Tutorial)
williamwilsond32williamwilsond32 wrote 02/09/2026 at 12:17 • 5 min read • Like
Have you ever watched a craft video and thought, “That stencil looks simple, I can do that,” and then felt not sure once you opened the Cricut Design Space app? Most of the beginner crafters start this way. You may want to paint a name on a wall sign or add a design to a jar, but once you choose a design, questions pop up. Which material should you use? How big should the stencil be? Will it tear while cutting?
This is where a Cricut machine really helps. It lets you create custom stencils that fit your project, whether you plan to use paint, ink, or paste. You can cut clean different shapes, letters, and patterns that are hard to achieve by hand. With the right steps, stencil making becomes simple instead of confusing.
In this post, you are going to learn ‘how to create a stencil with a Cricut cutting machine‘ from start to finish. We will go through the required materials, create a design, make a material choice, and more. By the end, you’ll feel ready to use your stencil with confidence and get clean results without wasting materials.
Materials Needed to Make a Stencil
Before you start creating a ‘custom stencil‘ with your Cricut machine, it’s better to gather all the tools and supplies you need.
Designing a Stencil in Cricut Design Space
To design a stencil in Cricut Design Space, you will need to know the basics.
  1. Open the ‘Cricut Design Space app‘ and create a new project. You can add a shape, like a square or rectangle, and resize it to match the stencil size.
  2. Next, upload an image, add text, or select a design from the library, then place it over the base shape.
  3. Make sure the design is spaced well and includes small “bridges,” so all parts stay connected after cutting.
learn-how-to-make-stencil-design-with-Cricut-machine
  1. When everything looks right, select the base and design, then use the Slice tool to turn your artwork into cut-out spaces.
  2. For designs with multiple pieces, use the Attach tool to keep everything lined up before cutting.
Cricut-design-space-download-application-for-windows-mac
Preparing Your Cricut Machine
Before you start cutting, set up your machine properly.
  1. First of all, choose the right material setting in ‘Cricut Design Space‘.
  2. Pick a setting that matches your stencil material, such as vinylacetate, or a custom option for thicker sheets.
  3. After this, you have to check the blade. A fine-point blade works for most stencil materials, but thicker Mylar may need a deep-point blade.
  4. Now, place your stencil material on a cutting mat.
  5. Smooth it down so there are no bubbles or wrinkles.
  6. If your material has a protective film, then remove it before loading the mat.
Cutting the Stencil With Cricut
Once your Cricut crafting machine is ready, it’s time to cut the stencil.
  1. In ‘Cricut Design Space‘, click the Make It button and send the design to your machine.
learn-ho-to-make-stencil-with-cricut-machine
  1. Now, load the mat, and press the ‘Go‘ button. While the machine is cutting, stay nearby to make sure the material stays in place.
  1. When it finishes, unload the mat carefully.
Weeding the Stencil
Weeding the Stencil cutting mat
After unloading the cutting mat, the next step is to remove the cut-out pieces you don’t need using a ‘weeding tool/scraper‘. You can start from the outer edges and lift the unwanted parts. You have to work gently and take your time with small details. Pull the material back at a low angle to avoid tearing. If any edges look rough, then smooth them to keep your stencil clean and sharp.
learn-how-to-design-with-Cricut-machine-new-stencil-designs
Frequently Asked Questions (FAQs)
How to Make Stencil With Cricut Explore Air 2?
Learn how to make a stencil with your Cricut Explore Air 2 machine, follow the steps in the section below:
How to Make Stencil With Cricut Maker 3?
If you want to create a custom stencil using your Maker 3, then follow the steps below:
How to Make Stencil With Cricut Joy Xtra?
Here are the steps you need to follow to make a stencil with your cutting machine.
Source : https://mycricut-design-app.com/how-to-make-a-stencil-with-cricut-complete-tutorial/
Like
