How PCB Hole Copper Thickness Affects Your Soldering Process
pcbmasterpcbmaster wrote 04/03/2026 at 07:35 • 4 min read • Like
When designing printed circuit boards (PCBs), most hobbyists and engineers focus on the component layout, routing, and overall design. But one aspect that is often overlooked—yet can significantly impact the quality of your work—is PCB hole copper thickness. While it might not be the first thing that comes to mind, the copper thickness in the PCB's holes plays a crucial role in the soldering process. In this article, we'll dive into why copper thickness matters, how it affects soldering, and what to consider when choosing the right copper thickness for your projects.
What Is PCB Hole Copper Thickness?
First, let’s quickly define what we're talking about. In a PCB, holes are created for through-hole components, vias, and sometimes even for mounting. These holes are plated with copper to create electrical connections between different layers of the board. The copper thickness refers to the amount of copper plating inside the hole, which is critical for ensuring the electrical integrity and mechanical stability of these connections.
Why Copper Thickness Matters for Soldering
Copper thickness inside PCB holes directly impacts the thermal properties and electrical conductivity of the connection. This, in turn, has several important effects on the soldering process:
1. Heat Dissipation During Soldering
When soldering, heat is applied to the metal pads and the surrounding PCB area. The copper inside the hole acts as a heat sink, drawing heat away from the solder joint. If the copper is too thin, it might not be able to absorb and dissipate the heat efficiently, leading to the following issues:
2. Mechanical Strength of the Joint
The copper plating in the hole isn’t just there for electrical conductivity—it also plays a role in the mechanical integrity of the solder joint. A thicker copper layer creates a stronger, more robust bond between the component lead and the PCB. Without enough copper thickness, the joint may lack sufficient mechanical support, leading to potential reliability issues, especially in high-vibration or high-stress environments (think automotive or industrial applications).
3. Current Carrying Capacity
For designs that involve high current or power electronics, the copper thickness inside the PCB holes is crucial to prevent thermal runaway or poor conductivity. A thicker copper layer inside the hole ensures the joint can handle more current without excessive heat buildup, reducing the risk of failure. For standard consumer electronics, this is less of a concern, but in high-power circuits, this could be the difference between a project that works for a few hours and one that lasts for years.
4. Solder Flow and Wettability
The ability of solder to flow into the hole is essential for creating a solid electrical connection. A thicker copper layer can sometimes create more resistance to the solder’s flow, especially if it’s not adequately heated or if the hole is too large. Conversely, too thin a copper layer may cause solder to poorly adhere or create weak bonds. Proper balance is key!
How to Choose the Right Copper Thickness for Your PCB Design
Now that we understand the importance of copper thickness in PCB holes, how do you go about choosing the right one for your project? The decision depends on several factors, including the type of components you're using, the power requirements, and the expected stresses on the board. Here are a few general guidelines:
1. Standard vs. Heavy Copper
Most PCBs are manufactured with a standard copper thickness of about 18-35 microns (0.7 mil to 1.4 mil). This is typically sufficient for most consumer-grade electronics, where current demands are low, and there isn’t significant thermal stress.
However, for power electronics or high-performance boards (such as RF circuits or automotive applications), you may want to opt for heavy copper. Heavy copper has a thickness of 70 microns or more (2.8 mil or thicker) and offers better heat dissipation, current-carrying capacity, and mechanical strength.
2. Consider the Size of the Hole
The size of the hole and the type of component you're soldering into it will also influence your copper thickness choice. For example:
3. Via Size and Aspect Ratio
When designing multi-layer boards, you need to consider the via size (the hole size) and the aspect ratio, which is the ratio of the hole’s depth to its diameter. A larger via requires more copper to maintain the connection’s integrity, while smaller vias may not need as much. Larger vias with heavy copper plating are essential for high-frequency signals or high-current applications.
How to Optimize for Soldering Success
Here are a few tips to ensure you get the best results during the soldering process:
Conclusion
In the world of PCB design, copper thickness in the holes plays a bigger role than most people give it credit for, particularly when it comes to soldering. Whether you’re building a DIY circuit or designing a high-performance board, understanding how copper thickness affects heat dissipation, mechanical strength, and current carrying is key to ensuring your solder joints are reliable and your board performs optimally. By factoring copper thickness into your design early on, you’ll save yourself headaches later and end up with more professional, reliable results.
Like
