How to Recover Data from an External Drive on Mac?
ericEric wrote 09/30/2026 at 11:20 • • 8 min read • Like
Storage device do not last forever, and external drives connected to your Mac are no exception. However, many drive-related issues are logical rather than physical. In most cases, the hardware is still functioning, but macOS can no longer access the stored data due to file system corruption, accidental formatting, improper ejection, partition damage, or mounting problems.
These are just some of the situations that can make files inaccessible, and in many cases, the data can still be recovered. With the right approach and recovery tools, you may be able to retrieve your lost or deleted files. This guide walks you through several ways to recover data from an external drive on Mac, covering both macOS’s built-in utilities and dedicated data recovery software.
How to Not Make It Worse Than It Already Is?
Data recovery is about prompt action. Files usually become unrecoverable not because of the original issue, but because of what you do after you notice that the data is missing. Before attempting any recovery method, keep these precautions in mind:
Ways to Recover Files Lost from an External Drive on Mac
The methods below are arranged from the simplest and safest options to more advanced recovery techniques. Begin with the first method and move to the next only if necessary. For each approach, you’ll find guidance on when it’s appropriate, when it’s better to avoid it, and the exact steps to follow.
1.      Check the Trash
When you delete a file on your Mac, the OS doesn’t immediately erase it and moves it to the Trash folder. This is different from Windows, which sends files from external hard drives to the Recycle Bin, but permanently deleted files from the USB flash drives and SD cards straight away. Your files may simply be sitting in the Trash waiting to be restored.
2.      Restore from a Time Machine Backup
Time Machine is a native utility on macOS which is designed to create incremental snapshots of your system. Time Machine stores hourly backups for last 24 hours, daily backups for the previous month, and weekly backups for older data. It automatically deletes the oldest backup first when the backup drive fills up.
While it is one of the quickest recovery methods available, it requires prior setup and does not include external drives by default. To make sure that your external drive is backed up, you need to manually add it. Open System Settings > General > Time Machine and click Options. If your external drive appears in the "Exclude from backups" list, it isn’t being backed up, if not, your data is safely backed up.
3.      Use Mac Data Recovery Software
When you don’t have a Time Machine backup and the Trash is also emptied, the best way forward is to use a free Mac data recovery software. It deep scans the drive’s storage sectors and rebuilds missing files directly from their internal data signatures. The files are recoverable as long as the drive is detectable in Disk Utility and the existing data is not overwritten.
4.      Restore from iCloud or Other Cloud Backups
Don’t forget to check your cloud storage. If you use services like iCloud Drive, Dropbox, Google Drive, or OneDrive alongside your external drive, you might find copies of your file waiting for you online. You can then recover files by downloading them again. This isn’t a general-purpose solution for everything, but it works great for synced documents and media.
iCloud Drive
Because iCloud Drive syncs across your Apple ID, you can access your files from any of your connected devices. If you accidentally delete something, don’t panic. iCloud shifts the deleted items to the Recently Deleted folder and keeps them there for up to 30 days before removing them permanently.
Alternatively, whether you use Dropbox, Google Drive, or OneDrive, each service provides a temporary safety net by holding onto your deleted data. Free accounts generally give you a 30-day window to act and reclaim your files.
Each service also keeps version history for files that were modified rather than deleted which is useful if a document on your external drive got corrupted or overwritten and you had a synced copy. Right-click the file in the web interface and look for Version history or Previous versions.
5.      Repair the Drive with Disk Utility
If your external drive starts acting up, corrupting your data, or locking you out of your files, you can use a built-in Mac tool called Disk Utility. Inside, you'll find a feature named First Aid. Running this tool will scan your drive and fix the file system errors responsible for making your files unreadable in the first place.
6.      Contact a Professional Recovery Service
When all DIY methods fail or if your drive has severe physical damage – a professional data recovery lab like Stellar Data Recovery Lab-Services is the last resort. They have Class 100 clean rooms and specialized equipment to repair hard drives or salvage data from damaged media. It’s expensive, but can recover data that software cannot.
Steps:
Recovery services can often get data off drives that are toasted, for ex. a failed SSD controller or scratched HDD platters. However, success is not guaranteed and costs can be high (often hundreds to thousands of dollars). Use this when your data is extremely critical (like business records or irreplaceable memories) and all software fixes have failed.
How to Prevent External Drive Data Loss
The cheapest data recovery is the one you never have to do. A few habits cover most of the failure modes that lead people to articles like this one in the first place.
Wrapping Up
If you have just lost important files from your external drive, don't panic. This guide walks Mac users through seven different recovery strategies, ranked from the easiest DIY fixes to the most advanced options available. Start with checking the Trash, restore from Time Machine or cloud backups, use data recovery software, and repair the drive via Disk Utility. It also covers key precautions to take before attempting recovery, a cause-and-method lookup table, special scenarios like undetected drives and accidental formatting, and tips to prevent data loss in the first place.
Like
