The uCompute Ecosystem: Three Years of Evolution
jp-michonJP Michon wrote 11/11/2026 at 14:44 • • 3 min read • Like
Originally, my goal was never to develop a unified hardware platform. It happened by accident—or rather, out of necessity. Since I manufacture my PCBs strictly for personal use, I only order two or three units of each revision. Over time, whenever a design met my needs, I naturally began standardizing the layout across newer boards.
The Genesis: "BareMetal" (Early 2023)
It all started with the "BareMetal" board in early 2023. This prototype gave birth to the first generation of the uCompute, establishing the signature user interface layout that remains to this day: an onboard display with three tactile buttons positioned right underneath.
Enter the RP2350: uCompute 2 (Fall 2025)
When the RP2350 microcontroller became available through suppliers in mid-2025, it paved the way for the uCompute 2 in the fall of 2025. Sharp-eyed makers will notice a few key hardware upgrades on this red board, including the transition to a USB-C port and smaller 0603 surface-mount components.
Back to Basics: uCompute Classic v1.3 (December 2025)
In December 2025, I released version 1.3 of the original RP2040-based uCompute. This revision adopted the standardized I/O header configuration and USB-C connector introduced on the uCompute 2. I also added a handy option to mount an OLED screen (SSD1306) as an alternative to the standard IPS display.
Accessible to All: uCompute Junior (November 2026)
The latest addition to the family, the uCompute Junior, born in November 2026. It is essentially a "bring your own Pico" version of the uCompute. Designed to be much easier to hand-solder, it uses larger 0805 components and features dedicated headers to plug in an official Raspberry Pi Pico (Pico, Pico W, Pico 2, or Pico 2 W).
I created this board after realizing that assembling my dense, fine-pitch PCBs wasn't accessible to everyone. My goal is to make the ecosystem approachable for schools, fablabs, or hobbyists looking for a low-cost experimentation module without getting locked into proprietary ecosystems.
A Color-Coded Lineup
Looking at the full family portrait from top to bottom, you can also see an intentional color-coding scheme take shape across the generations. Black represents the original RP2040-based uCompute Classic—the baseline standard that started it all. Red highlights the high-performance uCompute 2 powered by the RP2350, signaling a step up in processing power and hardware density. Finally, white was chosen for the uCompute Junior to emphasize its educational, beginner-friendly "bring your own Pico" philosophy—making the black silkscreen labels crisp, clear, and effortless to read while hand-soldering. Plus, for a maker like me with a workbench overflowing with circuit boards, it makes it way easier to spot the different PCB generations at a glance without having to reach for my glasses!
A Modular Add-On Ecosystem
The uCompute ecosystem is more than just mainboards; it also includes a growing family of plug-in modules. Originally, the uCompute was designed to host a W5500 Ethernet module via a connector on the back of the PCB, right under the screen. Because that header uses an SPI bus, it opened the door to creating adapters for all kinds of hardware:
I am skipping a few specialized add-ons for now, as those will be introduced alongside their own dedicated projects!
Dive Deeper into the Ecosystem
Want to build your own board, explore the hardware schematics, or check out our MicroPython guides? Visit the centralized uCompute Ecosystem Wiki for full assembly instructions, hardware comparisons, and example projects.
Like
