What's your favorite op amp?
James wrote 01/05/2018 at 20:09 • 1 pointI'm looking to expand people beyond the typical 741. What's your favorite Op Amp and why?
The day job uses the ADA4817. 400Mhz GBW for biological sensing. Audio gear at home uses the LF353, because it was easily available at Radio Shack & sounds good enough. The absolute best of the best for audio seems to be the OPA227.
Obviously the ones that have negative feedback... :P
For high-precision, low-frequency stuff I have a stock of MCP6V01's. +/-2 uV max voltage offset with +/-50nV/C drift (yes, it's a chopper). Noisier than some others, but relatively inexpensive for what you get.
Oh, and for audio you can't do much better than the NE5532, at least for the price.
