BLDC hardware emulation
helge wrote 04/30/2018 at 16:25 • 0 points
Something that bothers me for quite a while now: why is there no small / cheap hardware emulator for BLDC motors? I've seen contraptions where two motors are coupled and one is actively driven whereas the other just has a resistive load hooked up to it or a rectifier at best.
There's really nothing wrong with connecting BLDC driver chips back-to-back with inductors in between.  Here it's being done to benchmark a large 3 phase inverter but the principle is pretty much the same.
https://ai2-s2-public.s3.amazonaws.com/figures/2017-08-08/b9e272bb34028b84dabf034421b8238c30d30f93/6-Figure11-1.png
Allegro makes an array of sensorless BLDC chips with sinusoidal and trapezoidal output modes and different options to set torque and nominal rotation speed.
https://www.allegromicro.com/de-DE/Products/Motor-Driver-And-Interface-ICs/BLDC-Drivers.aspx
All that's missing is a way to scale the sensed average current to e.g. a VCO control voltage and fudge around with loop stability to match the host BLDC controller.
At the end of the day I assume noone ever bothered to look into it because... I mean... why would you?
Unless you need to emulate a BLDC motor for arbitrary controller chips of a host device (DLP beamer :D) to be hacked...
ps. candidates for sensorless BLDC controllers:
Texas Instruments DRV10983
Allegro A4942, A4964 to name a few
ON Semi LB11683H
Owo JY02A ... just joking
