After evaluating the RDA5807M and the SI4703, I found out that it's hard to get good quality RDS-reception. I only tested on a breadboard. The air wire connections and the absence of a large enough ground plane aren't helping to get good reception quality.
The used development platform has an influence as well. The ProTrinket 3V, powered by the FTDI has a average 5dB better RSSI than the Nucleo STM32F103. On the Nucleo, it wasn't possible to receive four consecutive blocks without error. The SI4703 had to be set to RDS-debug mode to get at least some RDS-info.
RDA5807M
- This chip is based on the SI4703. The RDA5807M datasheet even contains statements that have been literally copied from the SI4703 datasheet.
- There's no error checking on the last two of the four RDS blocks. Block 3 and block 4 contain the useful data. The only way to "guarantee" data integrity is only passing on data that has been received twice identically.
- Reception quality is acceptable for audio, but not for RDS. There's only one station that gives me acceptable RDS reception.
- The RDA5807M has more or less the same settings as the SI4703, but these are located at other registers. So they're not firmware compatible.
- Very little info about the RDA5807 : 2 datasheets (in english) and two programming manuals (in chinese)
- Available on module by AliExpress
Si4703
- Extensive info available on SiLabs website
- If you need RDS, better to choose this IC instead of RDA5807M. The RDS reception quality isn't better, but at least you'll be told what RDS-blocks are valid and which ones contain too many errors.
Si4749
- RDS only, no audio
- hard to solder QFN package
- Acceptable price : €2.30/pce at Digikey
Si4731-D60
- Used in the more recent versions of the taiwanese Sangean WR-2.
- Expensive : €13.85/pce at Digikey
Christoph Tack
