// Videx Videoterm Card Emulator
// by Augusto Baffa feb 2024
// Based on Apple II Simulator
// by Peter Koch, May 6, 1993
int videx_slot = 3;
bool card_videx = true;
bool card_videx_mem_on = false;
bool card_videx_80col = false;
class VidexCard {
//notes:
// To turn on/off 80 columns mode:
// Write at 0xC058 or 0xC059
// card_videx_80col = (addr == 0xc059);
// To Control the card:
// IOSEL (0xC300-C3FFF - slot 3)
// Read
// r = videxcard.getRomIoSel(addr & 0x1FF);
// card_videx_mem_on = true;
// Write
// DEVSEL (0xC0B0-C0BF - slot 3)
// Read
// r = videxcard.getC0SLOTX(addr);
// Write
// videxcard.putC0SLOTX(addr, val);
// IOSTB (0xC800-CFFF)
// Read
// if (((addr >> 9) & 0b11) == 0b11) card_videx_mem_on = false;
// if (card_videx_mem_on && addr >= 0xC800 && addr <= 0xCDFF)
// r = videxcard.getSLOTC8XX(addr & 0x7ff);
// Write
// videxcard.putSLOTC8XX(addr - 0xC800, val);
// To Render:
//for (int y = 0; y < 25; y++) {
// for (int x = 0; x < 80; x++) {
// int vkeycode = videxcard.getCSLOTXX(x, y); // get ascii code from memory
// bool vinverse = videxcard.isCursorPosition(x, y); // check cursor position to inverse
// for (int i = 0; i < 9; i++) {
// int video_bits = videxcard.getVideoBits(vkeycode, i); // get bits for the current char/scanline
// if (vinverse)
// display_bit_80col(renderer, x, y, ~video_bits, i); // render char/scanline
// else
// display_bit_80col(renderer, x, y, video_bits, i); // render char/scanline
private:
uint8_t videx_rom[0x400]; // 0x0400 at C800-CBFF
uint8_t videx_chars[0xfff]; // 0x0-0x7ff rom 1 | 0x800-0xfff rom2 character rom (12x8) Matrix)
uint8_t videx_vram[2048]; // 0x0800 at CC00-CDFF in 4 banks of 0x1FF
// internal variables
int videx_bankSLOT, videx_regvalSLOT; // active memory bank, selected register
unsigned char videx_regSLOT[17];// registers of the CRT-controller
//int videx_oldcursorSLOT; // old cursor position
//int videx_upperSLOT, videx_lowerSLOT; // cursor size
// Registers
// register r/w normal value Name
// 00: w 7B Horiz. total
// 01: w 50 Horiz. displayed
// 02: w 62 Horiz. sync pos
// 03: w 29 Horiz. sync width
// 04: w 1B Vert. total
// 05: w 08 Vert. adjust
// 06: w 18 Vert. displayed
// 07: w 19 Vert. sync pos
// 08: w 00 Interlaced
// 09: w 08 Max. scan line
// 10:0A w C0 Cursor upper
// 11:0B w 08 Cursor lower
// 12:0C w 00 Startpos Hi
// 13:0D w 00 Startpos Lo
// 14:0E r/w 00 Cursor Hi
// 15:0F r/w 00 Cursor Lo
// 16:10 r 00 Lightpen Hi
// 17:11 r 00 Lightpen Lo
// The registers are addressed as follows:
// To write To read
// LDA #$ LDA #$
// STA $C0B0 STA $C0B0
// LDA #$ LDA $C0B1
// STA $C0B1
public:
int getC0SLOTX(int adr)// 0x0400 at C800-CBFF
int value = 0x00;
//define current memory bank
videx_bankSLOT = (adr & 0x000c) >> 2;
if (adr & 0x0001)
// get current register value
value = videx_regSLOT[videx_regvalSLOT];
else
// define current register
videx_regvalSLOT = value;
return value;
void putC0SLOTX(int adr, int value)// 0x0400 at C800-CBFF
if (adr & 0x0001)
// set current register value
videx_regSLOT[videx_regvalSLOT] = value;
//10:0A Cursor upper //11:0B Cursor lower
if ((videx_regvalSLOT == 10) || (videx_regvalSLOT == 11))
modifySLOT();
//14:0E Cursor Hi //15:0F Cursor Lo
if ((videx_regvalSLOT == 14) || (videx_regvalSLOT == 15))
cursorSLOT();
//13:0D Startpos Lo
if (videx_regvalSLOT == 13)
redrawSLOT();
//12:0C Startpos Hi
else
Read more
