VS Code Build Lights: Broadcasting Success And Failure Over UDP
02/27/2026 at 18:41 • 0 commentsMake Your Editor Talk To Your Hardware
Most developers rely on on-screen notifications to know whether a build succeeded or failed. But if you’re working across multiple monitors, running CI pipelines, or doing embedded work with long build times, you sometimes want something more physical — like a blinking LED, a buzzer, a display, or even a small dashboard that lights up when things break.
So I built a simple tool that lets VS Code broadcast UDP messages every time a task completes — success or failure — allowing any hardware on your network to react instantly.
This lets you create your own build lights, IoT indicators, or automation triggers with almost zero setup.
Repo: https://github.com/sdrshnptl/notifybuildresult
🛠 What It Does
The extension watches VS Code tasks. Whenever a task ends, it sends a UDP broadcast packet to your LAN.
Example payload:
{ "task": "Build Firmware", "status": "success" }Anything that can listen on UDP (ESP32, Raspberry Pi, Node.js, Python, Arduino, home automation, etc.) can act on it.
This means you can build:
- A green/red RGB LED build status light
- A desktop notifier on your Pi
- A wall-mounted display
- A Slack/Discord notifier (via a UDP-listening script)
- A relay-triggered siren when a build fails (yes, you can…)
⚙️ Why UDP?
UDP broadcast is:
- Zero configuration
- No pairing or auth needed
- Instant and connectionless
- Supported by every IoT chip, MCU, and OS
If your LAN has devices listening on port 10203, they will instantly react to VS Code builds.
UDP is perfect here — even CI systems sometimes use beacons to announce events.
🔧 How It Works Internally
The extension hooks into VS Code’s task lifecycle using its extension API.
When a task finishes, it:
- Collects task name
- Determines status (success / fail)
- Formats a JSON message
- Sends a broadcast UDP packet
Simplified Flow Diagram
+-------------+ +--------------------+ +-----------------------+ | VS Code |------>| notifybuildresult |----->| UDP Broadcast (10203) | | Task Finish | | Extension | | JSON Payload | +-------------+ +--------------------+ +-----------------------+ | v +-----------------------------+ | Any Device Listening on LAN | +-----------------------------+
📡 Example: ESP32 Build Light
Here’s the simplest ESP32 listener:
#include <WiFi.h> #include <WiFiUdp.h> #include <ArduinoJson.h> WiFiUDP udp; void setup() { WiFi.begin("ssid", "password"); udp.begin(10203); } void loop() { char buffer[256]; int len = udp.parsePacket(); if (len > 0) { udp.read(buffer, len); StaticJsonDocument<256> doc; deserializeJson(doc, buffer); String status = doc["status"]; if (status == "success") digitalWrite(LED_BUILTIN, HIGH); else digitalWrite(LED_BUILTIN, LOW); } }The LED instantly flips green/red based on your build result.
💻 Node.js Listener (Desktop or Pi)
import dgram from "dgram"; const socket = dgram.createSocket("udp4"); socket.bind(10203, () => console.log("Listening for VS Code build results...")); socket.on("message", (msg) => { console.log("Build Event:", msg.toString()); });One script, infinite possibilities.
🔨 How To Install the Extension
Install from GitHub:
git clone https://github.com/sdrshnptl/notifybuildresult
Or load it manually via VS Code → Extensions → "Install from VSIX".
Full instructions are in the repo.
🧱 Use Cases
✔ Build light for embedded developers ✔ Notify a CNC system (Fanuc, Modbus, ESP32 gateways) ✔ Update a wall display or dashboard ✔ Flash LEDs on your workbench ✔ Trigger home automation when CI breaks ✔ Play sound effects when builds fail
If you can listen to UDP, you can automate it.
🎯 Why I Built It
I work with a lot of embedded, IoT, and automation systems. Builds can take time, and I wanted a simple visual indicator that didn't require switching windows. Most notification systems are cloud-based or require too much overhead.
UDP broadcast is a beautifully simple local-only...
Read more
