Unknown HV Diode Testing
05/30/2026 at 15:15 • 0 commentsRecently got some high voltage diodes of unknown properties. Decided to measure their breakdown voltage and estimate their specs based on similar sized models. This was a bit challenging due to the high voltage nature and my measurement setup,for breakdown voltage I am rounding to the nominal standard diode voltages (within 1kV). The leakage current at high voltage my meter only incremented in 100nA, so we are limited, I would expect these are inline with other typical ~1990's-2000's HV diodes.
Diode Parts:
- H1601-30
- CS140U10
H1601-30 Specs:
Measured the forward voltage:
Measured Breakdown Voltage & Leakage:
- V Breakdown = 20kV (>10uA)
- I Leakage @ 15kV = 250nA ± 50nA
CS140U10 Specs:
- V Breakdown = 10kV (>10uA)
- I Leakage @ 7kV = 100nA ± 50nA
Old Chips Found During Cleanup
11/08/2025 at 16:51 • 0 commentsAmazing how you can have spare parts sit in draws for 25 years untouched. I'm a fan of AMD so I was excited to find two of these are from them. I'm wishing I had a better microscope to de-cap and view the die. I'll have to figure out how to see if Evil Monkeyz Designz is interested in any of these for a de-capping.
Parts Shown Below:
M27C1001 - 1 Mbit UV EPROM AM27C010 - 1 Mbit UV CMOS EPROM AM27C512 - 512 Kbit UV CMOS EPROM AT89C55 - 8-Bit Microcontroller with 20KByte Flash
S19254 - NPN Transistor, OldParts
04/02/2023 at 18:35 • 0 commentsSummary:
The S19254 appears to be a high gain NPN transistor.
- Package: ?
- Vce = 60V ?
Performance Measurements:
Performance measurements taken at different operating points. Approximately 18 degrees Celsius.
Package Measurements:
Pins were confirmed with meter and in circuit testing.
See image above.
CDQ10656 - NPN Transistor, OldParts
04/02/2023 at 16:04 • 0 commentsSummary:
The CDQ10656 is a medium gain NPN transistor. Based on limited literature.
- Package: TO-5 | TO-39
Parameter Value Unit Vce 60 V Veb 6 V Ic 1 A ![]()
