Hackaday.io Hackaday.io
Sign up Log in
VR Skateboard with Arduino and Google Cardboard
An accelerometer/gyro goes onto an Arduino board and transmits the angular motion of the skateboard via bluetooth to a VR game.
matthewhallbergmatthewhallberg
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
2.6k views
4 comments
2.4k followers
  • Description
  • Details
  • Files 3
    • View all
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 4
View Gallery
2.6k
4
2.4k
14
Team (1)
  • matthewhallbergmatthewhallberg
Join this project's team
  • App and Code
  • Full Instructions
hardware
completed project
arduino Skateboard virtual reality Google Cardboard
Related lists
Atmel Arduino Projects
Arduino is an open source hardware platform for making interactive objects that can sense and control the physical world.
Virtual Reality Projects
Immersion with the virtual world with VR, DIY style!
This project is submitted for
  • Hackaday.com Tip Line
  • The 1kB Challenge
This project was created on 03/04/2016 and last updated 3 years ago.
Description
This is a really fun and easy project that can be done in about an hour. On the bottom of the skateboard is an accelerometer/gyro with an Arduino board that transmits the angular motion of the board via bluetooth to a little VR game I made in Unity for Android phones. So, when you turn on your Arduino and the bluetooth connects with your phone, you start moving forward. Lean left and you go left, lean right and you go right. Lift up the front wheels and your character will jump. This only works for Google Cardboard compatible Android phones....
You will need:
-A Google Cardboard style virtual reality headset.
-A skateboard.
-4 tennis balls (to keep from rolling away)
-An Arduino Leonardo (or Uno)
-Some jumper wires
-A mini breadboard
-An HC-06 bluetooth module
-An MPU-6050 accelerometer/gyro
-A 9V battery with battery box that has a on/off switch and a barrel plug (to power the Arduino -board)
-A soldering iron and maybe a hot glue gun
Details
Files
VRBoardUnity.apk
Android App
Android Package Archive - 27.51 MB - 03/04/2016 at 21:48
Download
VRinputBytesNew.ino
Arduino Code
ino - 3.45 kB - 03/04/2016 at 21:47
Download
Connections!
JPEG Image - 463.07 kB - 03/04/2016 at 21:46
Preview
Log In/Sign up to comment
Sign up with Github
OR
rabbani wrote 06/21/2016 at 16:15 • point
not able to find how to input the data from the bluetooth module to the untiy
rabbani wrote 06/21/2016 at 16:14 • point
how have you done the interfacing of the bluetooth module with the unity
matthewhallberg wrote 12/01/2016 at 08:54 • point
I used the Unity asset called bluetooth for microcontrollers.
matthewhallberg wrote 03/09/2016 at 15:52 • point
Looking for someone good with Unity to collab on a project, if anyone is interested.
Hackaday Prize 2019
Arduino-compatible board with 128x64 OLED display and 6 buttons for playing simple 2D games.
Project Owner Contributor
Tiny game console
mislav-brekaMislav Breka
ArduShield it is a development shield for most popular boards like Arduino UNO, Mini, Pro Mini, Nano, Micro, Leonardo and many others boards
ArduShield – most Hacker shield for ARDUINO
simonSimon
ATTINY816 on a small board designed to fit the arduino nano 3.0 terminal breakout
ATTINY basic stick
david-brownDavid Brown
Simple instructions to get an Arduino board working with the GCC compiler without the IDE: https://github.com/dsnider0909/hello_arduino
hello_arduino
dsnider0909dsnider0909
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "VR Skateboard with Arduino and Google Cardboard", please tell us the reason.
Send message
Remove Member
