distributed server with RPi
Building a distributed server with raspberry pi's on consistent hashing ring. also using GPU compute
Modern computers are often significantly impeded by issues stemming from memory access. As most systems use disk for large quantities of storage, there is a penalty for both random read latency and power consumption. In a distributed system, this means that accessing data sorted by a hashed key can be a bottleneck for client operations. Additionally, the wattage and price required to power a large server rack can be discouraging to those who want to host their own servers. Using low-power, diskless nodes, like raspberry pis (running with ARM 700 MHz CPUs), many of these problems can be solved. By running a large quantity of small nodes in parallel, a memory bandwidth comparable to a typical server rack can be achieved at only a fraction of the cost.
  • 6 × raspberry pi model B
  • 1 × network switch TP-LINK 8 port
Ella May wrote 11/15/2014 at 02:48 • point
how we will see if your project was working?
lixiaofaninusa wrote 05/07/2014 at 20:27 • point
Please see the website from description for benchmark results
lixiaofaninusa wrote 05/01/2014 at 07:18 • point
This is still an ongoing project. Welcome feedback!
