Arduino Network Analyzer
Network Analyzer on an Arduino Shield which covers from 0-72MHz.
The network analyzer shield uses an Analog Devices AD9851 DDS chip clocked at 180MHz which will output a sine wave at any frequency from 0Hz and 72MHz. The DDS output is filtered with a Butterworth LPF and then passed to a two transistor amplifier. The shield will output approximately 0dBm (maybe 1-2dBm if you turn the Pot up; may get distortion, though) into 50 Ohms. The output and input connectors are SMA. The power detector is an Analog Devices AD8307. It's inputs are terminated with a 50 Ohm load. There is no filtering on the input of the power detector so the chip is responsive from very low frequencies all the way up to 500MHz.
This is really three tools in one: a sine wave generator (0-72MHz @ 0dBm), a power detector (LF-500MHz, -70dBm to +10dBm), and, when used in concert together, a scalar network analyzer.
The license is the MIT License, as it seems to have almost no restrictions on use. Do what you will with it, just don't hold me liable if it goes wrong.
As an electrical engineer, I love test kit. However, it's really expensive. I have the idea of building a Spectrum Analyzer with a dual conversion superheterodyne architecture. It would cover DC to daylight and be everything I'd ever wanted...
But I decided to start smaller. Besides, one of the most important parts of a Spec An is the RBW filter. How do I know if I had a good one? I could use the Spec An itself to tell me or I could make a simpler piece of test kit (this Network Analyzer shield) that would help out in building all manner of RF things.
This was a great way to get my feet wet and learn many things about building circuit boards for RF work. What you see here is Rev 2. Rev 1 had many issues, the worst of which was the amplifier on the output. I used an Op Amp which couldn't swing rail to rail so I was getting lot's of distortion (that I could see on my Rigol 70MHz scope) and also made a really great oscillator at ~600MHz (which I only found when I put it on a Spec An at work (+3dBm... my bad, FCC, when I hooked it up to a short piece of wire and briefly listened to my sine wave signal on a short wave receiver)). I also screwed up the DC biasing... Oh well, that's why I made Rev 2!
I wrote a program to display the trace and control the board in Python. It has a known error where sometimes when decreasing the number of samples in a sweep, it throws an index out of array bounds error and stops working. I could fix it by putting a state machine into the program, but it works pretty well as is so I haven't done that yet.
Arduino_SNA_KiCad_Files.zip
Zip of files in my KiCad project folder.
Zip Archive - 96.57 kB - 03/09/2016 at 01:00
Download
Gerbers.zip
PCB Gerber FIles.
Zip Archive - 70.00 kB - 03/09/2016 at 00:58
Download
Arduino SNA Sketch.txt
Network Analyzer Arduino code.
plain - 2.26 kB - 03/05/2016 at 20:58
Download
Arduino Network Analyzer.py
Network Analyzer display source code.
x-python-script - 10.62 kB - 03/05/2016 at 20:55
Download
ArduinoSpecAn.pdf
PDF Schematic of the Network Analyzer Shield.
Adobe Portable Document Format - 52.00 kB - 03/05/2016 at 18:55
Preview
  • 1 × AD9851 Semiconductors and Integrated Circuits / Misc. Semiconductors and Integrated Circuits
  • 1 × AD8307 Amplifier and Linear ICs / Logarithmic Amplifiers
  • 1 × LM7301 Amplifier and Linear ICs / Operational Amplifiers
  • 2 × 2N3904 Discrete Semiconductors / Transistors, MOSFETs, FETs, IGBTs
  • 1 × KC5032A Frequency Control / Oscillators
  • New Version of the SNA!
    Brett Killion06/02/2018 at 14:02 0 comments
    This project has been silent for quite a while now but it is not due to lack of interest. I just don't have as much free time as I used to.
    I'm not sure if this is appropriate as a new log entry on the old SNA project or if it should be its own new project as it's undergone some pretty drastic changes!
    FIrst off, here is a shot of the new version of the board:
    The keen observer will note several changes:
    • It's tiny -- the new board measures about 40mm X 40mm.
    • I moved from a DDS sine wave generator to a Si5351 clock generator as the source.
    • It's not an Arduino shield -- the processor is now an STM32F042K6T6.
    So a bit about the new design. I have wanted to learn about embedded USB devices so I ripped off the bandaid and forced myself to learn how to make one by giving this board no other connectivity. (That being said, I haven't actually gotten this communicating over USB yet...)  The microcontroller is the second cheapest ST part that has USB built in (there is a cheaper package of the STM32F042 with 20 pins but I2C and USB use the same pins and therefore cannot be used concurrently) and costs around $2.50 in single quantity.
    I jumped to the Si5351 as my signal generator because I wanted to see if it would work. It is much cheaper than the DDS chips (about $1 vs $20) and contains three outputs. It is also capable of outputting between ~10 KHz and 200 MHz. Since it has multiple outputs, I chose to use two of them. As seen in the picture, they are both running through zero ohm jumpers into a switch but there are pads placed to populate a filter or an attenuator on each output. The output of the Si5351 is 50 ohms so that is convenient for RF work. It's referenced off of a TCXO running at 27 MHz so it should have decent frequency stability. Coincidentally, this also feeds the microcontroller and can be used to spin the PLL up to 48 MHz (divide by 9, multiply by 16) -- perfect to drive USB!
    The detector is still the AD8307. Since the board is powered via USB which is regulated down to 3.3V, the amp between the AD8307 and the microcontroller ADC is now just a buffer, no extra gain, so as to not saturate the ADC.
    Overall, I think this could be a great little board but I won't know until I get some USB communications implemented. I did some basic testing with the multimeter and proved that everything was at the correct DC voltages and then put together a blinky program using ARMs online editor/compiler thing (Note -- if you care about code size or speed, don't use that. A simple LED blinking program produced a binary file over 10KB in size!) so I know the board works. Now just to program it...
  • Update
    Brett Killion08/17/2016 at 14:50 2 comments
    After using this a bit, it works decently well but there are some areas that could use improvement:
    - The software can use some general polishing, most likely adding a state machine to avoid the error where decreasing the sweep size basically causes a seg fault.
    - The two transistor amp could probably use some rework. A high speed op-amp may be more suitable. Just be wary of the DC biasing...
    - I don't remember which specific inductors and capacitors I selected for the filter, but 72 MHz might be beyond their self resonant frequency. That's something I should have checked before ordering/soldering them.
    All in all, I am quite pleased with how this works. It's a phenomenal tool for measuring crystals for selection/characterization for use in crystal ladder filters. I haven't tested it with amplifier circuits or other frequency selective things but I suspect that below 30 MHz it's great and over any 1-2 MHz bandwidth it is quite flat. It's only when the response is taken from 1-72 MHz that you see the lack of flatness, but it's still quite usable (especially since I added the calibration feature)!
  • Uploaded KiCad and Gerber files
    Brett Killion03/09/2016 at 01:03 0 comments
    I uploaded the Gerber files for the project as well as the KiCad files. I wasn't sure how to get the KiCad project in there so I just zipped up everything that was in my KiCad project directory.
    If there is a better way to post the KiCad files, I'm all ears (eyes...?).
  • Software Design
    Brett Killion03/05/2016 at 20:50 0 comments
    The inspiration for this software came from Alexander Frank (http://www.changpuak.ch/electronics/Arduino-Shield-TOBI.php) who got it from Rich Heslip (http://rheslip.blogspot.com/2015/08/the-simple-scalar-network-analyser.html) who got his from PA2OHH (http://www.qsl.net/pa2ohh/11sa.htm). I made some pretty substantial modifications and in fact started over at one point but it's not my original idea so that's the history as best I know it.
    I wrote it in Python 3 (using Anaconda, which contained most of the packages, except PySerial, which I had to download separately) . Here is a screenshot from my Network Analyzer running:There is no option to select a port when it's running, you just have to know the port of your Arduino, edit the port name in the python file, then run the program.
    Also, if you decrease the samples there's a chance it will stop running due to an array index out of bounds error.
    All the controls are self-explanatory, I believe, with the exception of "Calibrate". When you click on Calibrate, it will complete a sweep at the current settings and save that trace as a reference. Ideally, this is done when you directly connect output to input. Then once the reference is created, connect the device under test to get a relative power reading. It moves out of relative mode back to absolute mode when either the frequency settings are changed or the number of samples per sweep are changed.
    There are some magic numbers in the code where it converts from the ADC readings to power levels. I roughly calibrated the power detector by using my oscilloscope to observe the peak-to-peak voltage of the signal at the detector inputs, then converted those to dBm. I adjusted the potentiometer to lower the signal strength and made another observation. I plugged the readings into a spreadsheet and then did a best fit line to get the equation. That's where the magic numbers came from.
    On the Arduino, the code is very simple. It parses a serial input for commands. If there is a number between 1 and 72,000,000, it sets the output frequency to that number. If it's anything else, it takes a power reading.
    When taking a power reading, it reads the ADC 16 times, adds the conversion results together, then bit shifts right twice. This oversampling and decimating does two things: it averages out noise and it effectively adds two more bits to the converter (going from 10 bits to 12).
    The sweep moves relatively quickly until the number of samples per sweep move up to 500 and 1000. At 1000 samples per sweep, it takes about 4 seconds to sweep the whole frequency range.
    Here is a sweep of a 10MHz crystal on the Network Analyzer:
    And here is a narrower sweep of the same crystal:
    Look for the full Python and Arduino code in the files section.
  • Hardware Design
    Brett Killion03/05/2016 at 18:38 0 comments
    There are several similar designs out there (most notably Alexander Frank's: http://www.changpuak.ch/electronics/Arduino-Shield-TOBI.php) which I only found after having designed my shield.
    The AD9851 takes in a 30MHz reference clock which it multiplies by 6 to get its internal 180MHz clock. It takes I2C commands to control it's output frequency. It's a current output whose maximum current is set by a resistor. I went with a 3.92k resistor to give a max current of 10mA. My sine wave is then centered at 5mA and swings from 0-10mA.
    I needed to filter out the aliased signal (basically 180MHz-desired output frequency) so I used a 7th order Butterworth LPF (because a flat passband is important here). I designed it for an input and output impedance of 100 Ohms. This way, the DDS sees essentially two 100 Ohm resistors in parallel (input and output resistors) giving a 50 Ohm impedance and converting my 0-10mA current into a 0-0.5V voltage swing. I was aiming for an output of 0dBm which is a 0.632V swing so I was a little short. I also wanted a buffer so that the DDS wasn't directly driving the output/load.
    Enter the two transistor amplifier. It's a common emitter followed by a common collector with feedback. The design came for this came from Rich Heslip (http://rheslip.blogspot.com/2015/08/the-simple-scalar-network-analyser.html).
    The schematic of my DDS/Filter/Amplifier is shown below:I added the 1K potentiometer to give some control to the output signal level. Turned up to 1K, the output is very small as it basically works as a voltage divider (it appears in series with the amplifier input impedance which is about 70ish Ohms). Turned down to zero, you get horrible distortion as the amplifier goes into saturation. In between though, you can finely tune the pot to give a nice 0dBm output sine wave.
    The input goes straight to a 51 Ohm resistor (no input filtering) to provide a broadband match. This means that the power detector is more sensitive to noise and such but also means it can be used as a power detector up to 500MHz. The output of the Analog Devices AD8307 (logarithmic power detector) goes to an Op Amp. This buffers the signal before it goes into the Arduino's ADC and also multiplies it by 2 so more of the ADC's range is utilized.
    Look for the complete schematic on the main project page in the files section.
    I made the circuit on a four-layer board. RF traces run on the top layer and the I2C signals run almost entirely on the bottom layer. The board was made by Elecrow.
    Elecrow did a great job and even though I only ordered five boards, they shipped me nine. All had been tested (I could see the probe marks on the pads). I think it was ~$25 for the boards and I paid the $20 for 3 day shipping (otherwise, it would literally take the slow boat from China). For around $50, I had nine four-layer boards that were 5cm x 5cm in my hands nine days after I clicked the button to submit my order.
View all 5 project logs
Rich text editor
M Yea wrote 11/01/2021 at 04:54 point
the error where decreasing the sweep size basically causes a seg. fault can be easily solved by using "try: except:" phrases such as below.
if len(self.adcValue):
    try:
        # Read and interpret ADC value.
    except:
        SetupArrays()
Xerror wrote 01/11/2021 at 13:05 point
Hi Brett,
Thanks for the great project. Hopefully you are still prepared to answer a question for me about the first version (the arduino shield).
I was wondering if you could explain how you measure the gain (as an SNA) with just one log amp (AD8307) that seems to be connected single-ended. The signal to be measured comes in on the ac-coupled INP, but there is no reference signal on the INM (it is connected to ground for AC). Against what signal is the measurement signal compared for the gain measurement? Or am I completely missing the point?
I am looking forward to hearing from you.
Kind regards,
Rens
kf4mot wrote 02/23/2018 at 17:52 point
How about we change this to a 6 GHz PLL and power sensor?
rydel charles wrote 12/25/2017 at 02:43 point
By the way, why not get in chat whis Elektor ? The certainly could be interested in that ...
rydel charles wrote 12/25/2017 at 02:42 point
me too !
Charles
Montilien wrote 02/07/2017 at 19:53 point
Hi,
good work!
but I cannot launch python script under python 3.6.0
this release refuse installations of modules "serial" and "tkinter"
have you some idea to resolve this problem? I have tried python 2.7 so, with no more results...
Is it possible to obtain a .exe (windows binary executable) of your script?
Best regards
Andre
F1FHK
Brett Killion wrote 02/13/2017 at 15:00 point
I have only tried it under Python 3.5. Python 2 won't work. On my computer, I installed Anaconda Python and then also PySerial. That should be everything it needs to run. I can't give an .exe as I don't have windows (or know how to cross-compile it).
daedstudio wrote 02/15/2017 at 16:51 point
Uninstall all python distributions....
Install Anaconda 3 x64 or x86:
https://www.continuum.io/downloads#windows
Install PyCharm (Community version) from:
https://www.jetbrains.com/pycharm/download/#section=windows
Install in same order as downloaded....
Then you open PyCharm, and in the first prompt - "Welcome to PyCharm", you click - Configure > Settings.....
Then you click at - Project Interpreter
In the slide menu, you choose - C:\ProgramData\Anaconda3\python.exe
(It should be the only distribution, if you uninstalled everything before)
Push apply, and wait for the loading of all the libraries, should take a moment..
When done, exit PyCharm.....
Then you open cmd prompt as admin, and type:
pip uninstall numpy
/// Note: When uninstalled, check with pip list, to be sure that it's gone.
pip list
/// Then install numpy and pyserial..
pip install numpy
pip install pyserial
That should work....
And Brett.. I haven't forgotten to sent you a schematic.. I've just been so busy the last couple of weeks, so haven't worked much on it.. :o)
Marco Mauro wrote 11/16/2016 at 10:49 point
massive congrats very insipiring project, thank you for sharing !
I have some questions for my application:
- Is it possible to measure the quality factor (Q-factor) of a quartz crystal resonator @10 MHz nominal frequency, using your network scalar analyzer ? - If so, How can I measure the Q-factor starting from the output of the power detector log amplifier AD8307 ? Thank you so much for your help
Brett Killion wrote 11/17/2016 at 16:58 point
Connecting a crystal between the Signal out and Power in and running a frequency sweep will show the frequency response of the crystal (Q-factor can be calculated from that (BW_3dB/Center_freq)). I did this in the screen captures for a 10MHz crystal and the peak and trough is clearly visible.
Marco Mauro wrote 11/17/2016 at 17:03 point
thank you Brett  you helped me a lot !
Bill K wrote 03/07/2016 at 04:06 point
I'm interested in the KiCad files.  Thanks for the offer.
Matt Barnett wrote 03/06/2016 at 23:00 point
Very interesting work. I've needed a network analyzer for some time but sadly this one doesn't cover the frequency I'm interested in. For a modified design, I was thinking about the LTC6950(up to 1.4 Ghz) for synthesis and AD8317(1 Mhz to 10 Ghz) for sampling. Above 1.4 Ghz, it would probably be best to rely on an outside clock source for accuracy or even better, professional gear. Also, if common RF is magic, then microwave is voodoo, which seems like a circuit design nightmare.
Brett Killion wrote 03/07/2016 at 02:32 point
I still have an idea for a Spectrum Analyzer + Tracking Generator kicking around that would go up to 2 or 3 GHz. It would be based around the AD4351 (PLL+VCO) which covers 35MHz to 4.4Ghz. It would be a dual conversion superheterodyne setup.
I think it would be pretty complicated so that's why I warmed up with this bad boy.
Klima wrote 03/06/2016 at 21:35 point
Hello!
Wouldn't it be wise to shield the "IN" signal right from the connector?
Brett Killion wrote 03/06/2016 at 21:52 point
Yes. I couldn't think of an easy way to get it done though.
Since the signal is coming from the DDS at 0dBm, I wasn't too concerned about the noise floor (which is probably at -50 to -60dBm. I don't have a proper signal generator to test/calibrate it so I don't actually know). I did leave some bare copper around the AD8307 so a shield could be added later.
Shielding the chip is probably the best way to decrease the noise since it has the most area to pick up interference. The trace is relatively small by comparison so it wouldn't contribute as much (I don't think).
Francois Bujold wrote 03/06/2016 at 20:21 point
Could this be used to built an ascilloscope?
Brett Killion wrote 03/06/2016 at 21:34 point
The software or hardware? The software definitely could.
The hardware probably could not. The power detector is logarithmic so waveforms would look distorted. Also, the Arduino ADC is rather slow so bandwidth would be quite limited.
For an o- scope, your best bet would be to get a fast ADC (10MHz - 40 MHz) and connect it to something somewhat powerful, like an ARM microcontroller. Then you could read the samples and pass them to a host quick enough to get decent bandwidth.
Bottom line is: scopes are hard... that's why I built a Network Analyzer :)
Alexander Lang wrote 03/06/2016 at 18:11 point
I think this could be very useful.  I have been looking for a similar device for sometime.  Any chance you will be selling these or releasing the gerbers?
Brett Killion wrote 03/06/2016 at 21:28 point
I have thought a bit about selling them, in fact this is kind of my first step into market research. If there is enough interest I could probably put something together.
 I will also post the KiCad files so if people want to spin their own, they can!
miramarhacker wrote 03/07/2016 at 02:08 point
I would pay a fair price for one of these - just board or populated.  Nice job!
