17" Upcycled Monitor
17" monitor made with a laptop display, controller, and laser cut parts.
Using Dallas Makerspace's laser cutter to do some additive manufacturing through subtractive means.
Simple use of a laser cutter. The monitor won't be the fastest or the cheapest, BUT it will be a 60hz monitor that can be customized yourself and rebuilt later.
monitor.svg
The cutting templates for the monitor. Use of a drill to ensure that the holes align and go all the way through is a good idea.
svg+xml - 47.39 kB - 03/06/2016 at 10:45
Preview
  • 1 × 17" LCD Panel (YMMV) LG LP171WP4(TL)(N2) (Ebay is your friend)
  • 1 × LCD controller LCD controller for the display (get off of Ebay)
  • 8 × #8 bolts 2" long Electronic Components / Misc. Electronic Components
  • 16 × #8 Nuts Electronic Components / Misc. Electronic Components
  • 7 × 24x48 sheets of 0.22" acrylic From Home Depot... NOTE: It also works good with plywood.
View all 8 components
View all 2 project logs
  • 1
    Step 1
    Cut sheet material using a laser by way of the template.
  • 2
    Step 2
    Stack cut out pieces
  • 3
    Step 3
    Drill out holes
View all 18 instructions
Rich text editor
