Soldering (again), fingers, and hubris....
A project log for Raimi's Arm - Bionic Arm for Kids
Open source, high functioning, myoelectric, bionic arm for kids.
patrick-joycePatrick Joyce • 08/26/2016 at 09:42•2 Comments
Toni (my carer) assembling the redesigned hand.
So, dad had soldered up the prototype forearm lid (containing all the control electronics for the hand). It worked a treat, once we'd re soldered one wire, that was in the wrong hole. Finally, I could dismantle the test rig, with all its unsightly Dupont cables.
On testing this beautiful new, self contained, bionic arm, one thing soon became apparent. There was still too much friction in the finger tendon design, and the new elastic finger return mechanism was in need of improvement. So, I dismantled the test rig, safe in the knowledge that I wouldn't need it again (oh, the hubris!), and cracked on with a ground up finger redesign. We finally finished printing and assembling the redesigned hand this morning. We bolted it to the forearm, and got ready to test. Plugged in the power pack, turned it on.... and.... nothing happened. Then, after a few seconds.... fizzle BANG!, followed by a little puff of blue smoke.
Oh dear. And just as i'd thought i'd finally seen a glimpse of the light at the end of the tunnel.
And unfortunately, my dad is in France until next week. So we're busy putting the test rig back together at the moment. Finding out what went wrong will have to wait for dad's return from holiday. I did a visual inspection, and can't see any burnt components, or obvious shorts.
My only theory is that the 5v pro micro I am using couldn't cope with the 12.5v that the power pack was delivering? - as its only supposed to run on a maximum of 12v.
Do any of you lot have any opinions on whether this is likely or not?
Jarrett wrote 08/26/2016 at 15:28 • point
This doc from Sparkfun says it can take 6-16v, so that's not it:
https://cdn.sparkfun.com/datasheets/Dev/Arduino/Boards/ProMicro16MHzv1.pdf
Also worth noting that +/- 10% is expected for most things in electronics, unless otherwise specified. So if something is supposed to take 12v, it should generally be able to handle 10.8-13.2v without fuss. Not counting "absolute maximum values" written on datasheets.
Patrick Joyce wrote 08/26/2016 at 15:54 • point
Thanks Jarret. Thats a weight off my mind. Dodgy wiring by pops most likely then. I thought 12.5v wasn't significantly higher, but once i'd thought of it...
