unpacked and spaced out the legs
started to install the panel between the legs.... slightly off holes
chooching
brackets and panel
time to install
noticed there was too much oil in the headstock, and cross which could lead to issues later. so emptied some out
that's better,, we can use the extra oil on the g0704 ways now.
and mounted
check the oil levels
break it in, and do a test cut in steel. obviously we didn't empty out enough oil
aluminum to test to see if any visible harmonics etc , all good
All installed and ready to start the CNC planning
charliex
