Converting a G4003G lathe to CNC
watch as we break a perfectly good manual lathe
jarek319: "you can’t tune “fundamentally flawed” out of a system."
Conversion of a manual lathe to CNC. The G0704 project is in pretty good shape and we need a bigger lathe than the 7x10 harbor freight mini lathe, in case there is a zombie apocalypse or AvE comes to visit.
It'll be the usual suspects, not necessarily in this order.
Having it delivered and unpacked
VFD + Motor upgrade
Steppers
Controller board + software. Lathe capable and all that
Coolant delivery
Anguish
Waiting on the fedex to arrive.
they arrived
that is a big box
le unbox
  • Installation and testing
    charliex03/13/2016 at 17:10 0 comments
    unpacked and spaced out the legs
    started to install the panel between the legs.... slightly off holes
    chooching
    brackets and panel
    time to install
    noticed there was too much oil in the headstock, and cross which could lead to issues later. so emptied some out
    that's better,, we can use the extra oil on the g0704 ways now.
    and mounted
    check the oil levels
    break it in, and do a test cut in steel. obviously we didn't empty out enough oil
    aluminum to test to see if any visible harmonics etc , all good
    All installed and ready to start the CNC planning
View project log
Rich text editor
Arya wrote 03/08/2016 at 13:12 point
Also, all the pics kind of are unavailable
charliex wrote 03/08/2016 at 19:38 point
hmm i checked them in incog mode too
Arya wrote 03/07/2016 at 21:30 point
Thanks for all the pictures, really woke me up =)
