I like the cleverness of this project and how “neat” it looks. Forgive my question however: What exactly does it do? I’m asking because I’m truly interested! Thanks.
hi andrew, its just a 5V regulator based on the super common LM7805.
The reason i free-formed the circuit is because i didnt want to make a PCB. I needed somthing that was easy to integrate into a larger project and so i included the screw terminals for ease of use.
This dongle will take 10V DC From a rectified transformer and regulate it down to 5V to power a dev. board.
But form factor, ease of use and simple retrofit to an existing circuit was priority.
Im planning on letting it run for a couple of days under full load (actual intended use, not max LM7805 currents) and monitoring how hot it really gets (thingspeak!).... if i have to swap it once a year im happy.
The supply transformer has a 250ma max current and this will be supplying a lipo battery backed switching 3.3v supply (it has to go through the battery to work)... so "technically" it only needs to supply charging currents.
I liked how nicely the parts just merged.... it was destiny!
