5V Dongle
I needed to power a 5V project from a rectified transformer and needed something that was quick to build and easy to replace.
I think its pretty clear.
Simple, clean, and useful.
Turned out better than expected!
Rich text editor
Andrew Pena wrote 03/14/2016 at 08:30 point
I like the cleverness of this project and how “neat” it looks.  Forgive my question however:  What exactly does it do?  I’m asking because I’m truly interested!  Thanks.
Gabriel wrote 03/14/2016 at 12:36 point
hi andrew, its just a 5V regulator based on the super common LM7805.
The reason i free-formed the circuit is because i didnt want to make a PCB. I needed somthing that was easy to integrate into a larger project and so i included the screw terminals for ease of use.
This dongle will take 10V DC From a rectified transformer and regulate it down to 5V to power a dev. board.
LEVY wrote 03/09/2016 at 02:55 point
I kinda like it, but caps don't do well strapped to a heat source
Gabriel wrote 03/09/2016 at 12:28 point
Yeah, I gave that some thought too.
But form factor, ease of use and simple retrofit to an existing circuit was priority.
Im planning on letting it run for a couple of days under full load (actual intended use, not max LM7805 currents) and monitoring how hot it really gets (thingspeak!).... if i have to swap it once a year im happy.
The supply transformer  has a 250ma max current and this will be supplying a lipo battery backed switching 3.3v supply (it has to go through the battery to work)... so "technically" it only needs to supply charging currents.
I liked how nicely the parts just merged.... it was destiny!
