Of course one could manually hack binary files, but - that's uncomforatable even with regular WaveROM formats, and a pest with the rather complex format used in DWGS synthesis.
Luckily, someone (=me) had a bit too much time at hand and came up with a tool to make it easier:
The DWLUTION Waveform Manager.
Right now, we're in the process of doing some final tests before releasing it, but here's a little preview of what you can do with it.
The Waveforms used need to come from $somewhere, so there's several options of importing or creating them:
- Import WaveROM dumps or .wav files containing single-cycle waveforms:
Oh, of course you'll want to prelisten to the waveforms. No worries, we got you covered. The piano roll on the bottom of the main form will always play the currently selected waveform at the selected pitch:
Cheers,
Isa
Isa Twospirit
